PDA
View Full Version : Honda Ruckus and Scooters
Pages : [1] 2 3
  1. Honda c70 mystery noise
  2. Need Info - 2018 Honda Ruckus
  3. 2024 Ruckus bogging after warm
  4. Elite CH80 Flooding
  5. 2024 Ruckus front wheel "hops" when going above 25mph
  6. Big Ruckus no spark
  7. Bogging
  8. 2009 Metropolitan clicks but doesn't turn over
  9. New Ruckus Owner
  10. 2007 ruckus electric starter isn't working, any advice is greatly appreciated
  11. Honda Aero 50 Headlight Substitutes
  12. Ruckus stand not working properly
  13. Honda ruckus fuel pump not working . Bought 2 aftermarket ones no luck bought new OEM
  14. Hello I am new to scooters
  15. 2011 Ruckus
  16. 2009 Honda Ruckus ignition problem
  17. Main wire harness routing
  18. Stumped Cannot get Ruckus started
  19. Stumped with ruckus problem
  20. 2006 Honda Ruckus bogs down at 15 mph
  21. Big Ruckus rear brake
  22. Honda ruckus max speed of 15mph
  23. Paint Code
  24. resurrecting a long stored ruckus ...spits gas at WOT
  25. 2003 Ruckus Exhaust Replacement
  26. Honda Ruckus Turns Over But No Spark
  27. Runs great when cold, bogs down when hot
  28. Honda ruckus WILL NOT START
  29. Stalling
  30. Ruckus question about Altitude
  31. Need help with my ruckus
  32. Speed problem
  33. Battery not charging
  34. Air box
  35. Big Ruckus PS250 no crank
  36. 2022 NPS50 Ruckus less than a year old, revs up when throttled up but then stalls.
  37. ruckus rear turn signals
  38. 125cc swap for Ruckus?
  39. 2019 cfw 50
  40. Honda ruckus Performance Parts?
  41. Gas Cap - non-locking
  42. High RPM when throttle released
  43. 1 mile radius
  44. Starting problem please help
  45. Honda Ruckus Parts
  46. Ruckus rebuild cylinder question
  47. Need help with my ruckus
  48. Starting issue
  49. Headlights not working,power to relay,no trigger voltage. PS250
  50. OEM Muffler Install Troubles
  51. Ruckus Battery Issues
  52. Iridium spark plug - standard or high speed ?
  53. Aero 80 revived, but stalls out
  54. Engine only starts when I hold the needle jet open
  55. Ruckus bogging issue after a New Carburetor
  56. Replacing fuel pump
  57. LED HEADLIGHTS?
  58. 2006 Honda Ruckus Slow Cranking
  59. Bogging Issues
  60. Thumb throttle
  61. Honda ruckus vin location
  62. Honda ruckus valve shim question
  63. Rear shock options
  64. Quicker acceleration
  65. 2020 ruckus shudders(?) at speeds over 28
  66. Top Speed Loss, RPM Capped
  67. Fork Preload
  68. New Ruckus -- un drivable...
  69. New 2003 Ruckus owner
  70. Dead Metropoitan
  71. Wiring question
  72. 2006 reflex carb issue
  73. key on, then what?
  74. 2010 Honda 110 Elite
  75. Ruckus Mechanical Help
  76. Need help identifying this cable...
  77. 2010 Honda 110 Elite
  78. 03 Honda Ruckus Wont Idle/Cuts Off
  79. Looking for stock Ruckus engine
  80. 2009 Honda ruckus flutter after airbox eliminator kit
  81. Yep, another ruckus no start issue
  82. Stock Jack stand
  83. Replacing brake pads, adjuster?
  84. Ruckus Variator grinding into engine crankcase
  85. Speed Restriction Issues
  86. Need a new stock style rim for my GY6 Ruckus
  87. Cylinder Drain Bolt- Broken Off
  88. Should Drive Face be loose
  89. bad ecu?
  90. ruckus electric start
  91. Gas in oil, new to the game
  92. Stripped spark plug
  93. After half a year, I needed more speed. Guess what just came in the mail?
  94. Hello looking for some ruckus help
  95. Gy6 swap ruckus idle/running trouble!
  96. Bullet connector size
  97. Help with overheating
  98. Help with overheating
  99. New ruckus owner !! Need advice !!
  100. 2006 honda ruckus. Help with speed?
  101. Honda Ruckus has been sitting for 6 years
  102. Looking For Replacement Stock Exhaust
  103. Honda Ruckus ignition wiring.
  104. Ruckus starting problem and dies when giving throttle
  105. Any other Ruckus forums that are active besides facebook pages?
  106. My Honda Ruckus
  107. Zoomer 6500rpm cut
  108. bought a 2013 ruckus, wont start, no spark
  109. need help 08 metro honda
  110. Run away idle
  111. How To Do A Valve Adjustment
  112. Top End Rebuild?
  113. Primary drive shaft ?
  114. Need Starter Help 2013 Ruckus
  115. NEW OWNER - COMPLETELY LOST (MARYLAND)
  116. Ruckus starting issue
  117. winter gas
  118. 49cc to 80cc - engine rebuild after lock due to no oil
  119. Can’t get ruckus past 10mph
  120. Ruck wont start
  121. Ruckus won't start! Help!
  122. Starting Issue
  123. what is an LED Drive Unit? Ruckus Not Starting...
  124. 2008 honda ruckus fuel pump went out. Bought new pump,but it won't come on.
  125. Low idle speed slow at start then stalls unless I give it gas
  126. 09 ruckus
  127. 09 ruckus electrical headache
  128. 1996 Elite ch80 both side panels will not come off
  129. New Ruckus Owner
  130. Reflex carb question
  131. Ruckus keeps draining power please help
  132. Need help more speed !! Live in Florida!!!
  133. Cant get my led turn signals to work
  134. New Ruckus owner!
  135. New to this world need advise and guidance lol
  136. Ruckus wheel alignment
  137. ruckus not charging
  138. 2018 Ruckus runs and then dies
  139. 2013 fuse problem.
  140. Fat guy variator tuning
  141. Noob question
  142. Ruckus Rear Break Issues?
  143. 2006 Ruckus won't start
  144. Ruck won't start. HELP
  145. Ruckus Seat Help
  146. A better seat latch?
  147. Custom sub frame fabrication?
  148. LED Lights
  149. 2009 Honda Ruckus Wont Start! NEED HELP!!
  150. 2018 Metro Trouble Code Question
  151. Under seat tail light/turn signal TEST
  152. Gy6?
  153. 2007 Honda Ruckus
  154. Front wheel off centered
  155. Husband Passed Need questions answered about 03 Ruckus
  156. Transporting a Ruckus in a 2019 Jeep Cherokee
  157. 2015 Ruckus Electrical Help, Starting Related
  158. GET Starting Issue
  159. DAILY COMMUTE
  160. Someone please help!!
  161. Ruckus Steering Stem Nut
  162. help! ruckus broken?? bogging down?
  163. 2012 Ruckus No Start Conundrum
  164. Ignition help
  165. Safe rpm range for ruckus engine
  166. Relay clicking, bike not starting
  167. Wheel Alignment
  168. Ruckus Clutch/Final Drive Spline size
  169. Bolt size?
  170. Ruckus 10A Subfuse Keeps Blowing
  171. Honda Ruckus New Hampshire Motorcycle
  172. Ruckus won't idle
  173. clunking when pushing or when let off throttle
  174. New 2008 Ruckus Owners has a question
  175. 2012 Honda Ruckus not running right
  176. 2011 Ruckus Dies while driving
  177. Ruckus Runs, then dies and won't start
  178. Nxt ceo
  179. 2017 ruckus sputters when giving gas . 0-15 mph
  180. 2013 Ruckus won't idle
  181. My Bumper is dragging on my tire
  182. 2017 Ruckus wont start
  183. Can I put LED headlight bulb on my 2007 Honda ch80 elite
  184. Slight wobble on rear wheel
  185. Ruckus wont start - making a weird sound.
  186. cdi and vapor install
  187. Looking for gy6 exhausts
  188. 2003 ruckus bogging
  189. Need some help!
  190. Sputters at top end
  191. No electric ignition?
  192. Ruckonomics
  193. What upgrades really work?
  194. Need 3rd Party Input!
  195. Hiding wire harness and brake lines around front post?
  196. Fuel pump ?
  197. 2007 Honda Ruckus - low power and a engine tick
  198. Ruckus won’t start. Removed air box
  199. Auto choke sticking?
  200. Ruckus won’t stay running /battery issue?
  201. New Build, couple questions.
  202. Ruckus Starts Cold, Won't Start Warm, Doesn't Reach Top Speed...
  203. Ruckus under seat
  204. Ruckus won't start
  205. HELP! R6 running light turns off when signaling and brake light doesn’t work!
  206. no start
  207. Hi. I'm Jack, Ruckus newb and have a problem
  208. Hey I'm Ryan!
  209. ruckus 2005
  210. honda ruckus dragbuild
  211. 2009 ruckus
  212. Lock ideas for a Ruckus?
  213. Tranport Ruckus
  214. 2016 Honda Met, performance muffler
  215. Buying a used ruckus, what to look for
  216. Metropolitan fuel injection performance exhaust
  217. ruckus fires once, then won't fire
  218. Ruckus dimensions
  219. howdy how do I use this forum?
  220. Transport car rack for big ruckus
  221. Ruckus hesitates during acceleration - HELP!
  222. My 2005 Honda Ruckus won't start
  223. Honda Ruckus
  224. Importing a Zoomer from Japan to the US
  225. Ruckus Fuel Filer
  226. Ruckus won't start
  227. gy6 swap
  228. Things to look for when buying a used ruckus.
  229. Honda Ruckus Frame Extension
  230. GY6 Swap Parts
  231. Stock 50cc Parts?
  232. ignition frozen?
  233. Problems
  234. Engine miss firing
  235. 2013 ruckus nps50 bogs
  236. Buying a ruckus
  237. Warm up problem?
  238. need advice on honda scooter
  239. Looking to GY6 Swap
  240. Big Ruckus: There are NO Knobby tires ! Can I change out rim to get Knobby tires?
  241. Closed.
  242. CRAZY AUTOCROSS KART BUILD
  243. Looking to get a Ruckus.
  244. I need some help
  245. Getting into a ruckus
  246. Replaced battery now running lights wont work
  247. Ruckus Wont Accelerate (Or Idle w/o Throttle)
  248. Honda ruckus
  249. Freeman's Ground up Ruck Build
  250. Is this Ruckus worth it?
