Wheel Alignment
Wheel Alignment
So I have a 2015 Honda Ruckus that I have stretched and lowered but I ran into a bit of a problem. I went and got myself the 12x8 Douglas wheel for the rear and went through the process of getting the extra stuff to complete the conversion and it has gone well so far. But now the rear wheel is wide the alignment of the rear to the front is out of place. So I thought if I moved the engine stretch mount to side that would give me enough to put it back into alignment but no luck. So now I'm stuck with this dilemma and I just hit a brick wall with what I should do next. Please need advice!!!! Thankyou for your Time!!!!
Re: Wheel Alignment
What size was the engine mount, was it for a stock(skinny), 7 inch, or 8 inch wheel? If it was a stock or 7 inch, it will not work with the 8 inch wheel.
Are you using the GET or GY6 motor? What hub are you using on the rear wheel?
How far out of alignment is your wheel? Any pictures you have will be helpful.
If it is an 8 inch mount and it is not lining up properly you should get your money back.
Mike052
10
01-13-2012 04:53 AM
