Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
No electric ignition?
Old 05-20-2018, 09:41 AM
Default No electric ignition?
Howdy,
Have a new 2017 Ruckus with less than 400 Miles. All electrical works and it kick starts fine. Fully charged battery but the electronic ignition doesnít work.
When I hit the start button nothing happens, even when depressing both brakes.
any ideas? TIA
Triumph46 is offline
Old 05-20-2018, 10:26 AM
sTol2m's Avatar
Default Re: No electric ignition?
Have you checked the fuses? They are on the positive side of the battery terminal under a black plastic cover.
sTol2m is offline
Old 06-06-2018, 01:37 PM
I did check all the fuses and they are fine. The Ruckus kick starts easily but there is no sound at all when trying tonelectric start.
Old 06-07-2018, 10:02 AM
sTol2m's Avatar
Some more things to try:
1. Take the start/kill swicth controls off and make sure the start button & wires are connected properly. Be careful, there is a spring behind the start button that you don't want to lose.
2. The starter relay could need to be replaced(the big blue square one next to the fuses).
3. There is a ground wire(green i think) for the electric start just to the left and above the variator case, make sure there is a good connection.
4. I know you already charged it up but, the battery could be dead or faulty. My old Ruck ran fine with a dead battery, had to kickstart it every time but it still functioned like it should.
Have it checked out, Rucks love to kill batteries, lol.
sTol2m is offline
Old 06-07-2018, 10:28 AM
Very helful!! I will check all these things and report back!! On the blue starter relay... do you know which one it is? I THINK there are 2-3 blue boxes.
Old 06-07-2018, 11:36 AM
sTol2m's Avatar
The Starter Relay is the biggest one under the plastic cover, on the positive side of the battery terminal.
sTol2m is offline
Old 06-14-2018, 06:06 AM
I'm curious, any update?
Markomrtnz is offline
Old 06-14-2018, 06:37 AM
Canít figure it out. Fuses look good and doesnít appear to be the really. I recharged the battery, tightened down the terminals and the starter worked fine for a couple days.
Then the Ruckus somehow kills the battery.
ill be taking the Ruckus back to the dealer for service, as itís only 6 months old.
JxMac206
General Discussion and Debate
15
06-04-2008 03:31 PM
Redline96LX
Welding / Fabrication
16
12-06-2005 06:45 PM
Kwuaymaikrup
01-24-2004 08:08 PM
Quick Reply: No electric ignition?
  • Ask a Question
Question Title:
Description:
