Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Ruckus wont start - making a weird sound.
Old 06-22-2018, 02:21 PM
Default Ruckus wont start - making a weird sound.
Let me preface this by saying I know nothing about scooters and am a complete novice. The engine would not key start and i was able to kickstart it for about a week after the normal way to start gave out. It no longer will start either way so i went ahead and replaced the battery. I just replaced the battery and it still will not start. I am able to turn the electronics on (blinkers, red odometer light up) but that is the extent of it. Can any of you give me some pointers on where to go next? Thank you.
Soup10japan is offline
Old 06-23-2018, 07:44 AM
sTol2m's Avatar
Default Re: Ruckus wont start - making a weird sound.
Where is the weird sound coming from, the front of the bike or the engine area?
You could check the fuses under the plastic cover on the positive + side of the battery terminal.
You could try replacing the spark plug & coil(the wire connected to the spark plug).
Also listen for the fuel pump to activate when you turn the key, to make sure that it is working.
Hope this helps.
sTol2m is offline
yoshi_1r671
10-26-2013 07:04 AM
Sofakingtyte
05-29-2013 09:04 AM
Vangruver
03-09-2009 09:27 AM
Jake Is Gay
General Discussion and Debate
14
08-06-2003 02:56 PM
Quick Reply: Ruckus wont start - making a weird sound.
  • Ask a Question
Question Title:
Description:
