Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
cdi and vapor install
Old 06-15-2018, 11:27 AM
Default cdi and vapor install
I have a 2015 Ruckus and did the CDI install. I just installed the vapor spedometer but feel like it is at a high rev when on the kickstand. Do I have to install it differently because of the CDI?
Thalby is offline
Old 06-16-2018, 07:54 PM
sTol2m's Avatar
Default Re: cdi and vapor install
Hello, try adjusting the idle screw on your carb. It's the tall screw next to the end of your throttle cable, where it connects to the carb.
Make sure the throttle cable isn't binding and that it is tightly secured to the carb. Also make sure the throttle grip isn't sticking.
The Vapor speedometer is NOT the cause of the high revs, and no you don't have to install it differently.(As long as it works properly.)
Here's a free tip: Do one mod at a time and check that it works BEFORE adding other mods. Trust me, it will save you alot of cursing and head scratching.
I learned this the hard way. Hope this helps.
sTol2m is offline
cnyej1
General Discussion and Debate
53
07-13-2008 08:07 AM
2.0L EK
09-06-2005 12:21 PM
Turbo-LS
04-28-2005 08:24 AM
ComposiMo
01-27-2005 06:31 AM
Gmedalion
04-24-2003 06:02 PM
Quick Reply: cdi and vapor install
  • Ask a Question
Question Title:
Description:
