Slight wobble on rear wheel
Re: Slight wobble on rear wheel
What are you running, the stock wheel or a custom wheel with a hub?
The stock wheel could be bent. Does it wobble at speed or when not moving? (or both?)
If you have a fatty wheel, (DWT polished aluminum) then it is normal because its two wheels welded together and not balanced properly.
Check the axle nut and/or lug nuts are tightened. Maybe try Dyna-Beads to balance it.
Thanks for responding. I don’t believe the stock wheel is bent. It just moves very slightly left to right when I move it. No accidents or lay down.
Ok I did some checking, and yes it is a common problem.
It could be the wheel bearings need replacing, a bent axle(I hope not), or the washer is missing for the axle nut.
The stock wheels are not the best quality steel and have a tendency to warp after falls or potholes.
Take the wheel off and check for axle wobble. Check the wheel bearings for damage. Double check that axle nut & washer are tight.
Hope this helps.
Hope this helps.
Chicano
11
01-19-2005 08:14 PM
