3rd, 4th, 5th gearing
Old Aug 23, 2006 | 08:16 AM
type B16's Avatar
Default 3rd, 4th, 5th gearing
does anybody know the ratios of the 3rd, 4th, and 5th of both 98 and 96 jdm itr? my 98 4th seems slower than a 96 and the 96 catches up so i was thinking of swapping my 4th for a 96 4th and maybe even the 5th.
Old Aug 23, 2006 | 08:22 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: 3rd, 4th, 5th gearing (kingb16)
I'm pretty sure you can find that info in one of these threads....
Transmission - Gear Ratio - Calculators
http://bob123e.tripod.com/askb...r.htm
https://honda-tech.com/zerothread?id=111012
https://honda-tech.com/zerothread?id=86881
https://honda-tech.com/zerothread?id=778414 - Gear Ratio Worksheet
Transmission - Final Drive, Gear Ratio
https://honda-tech.com/zerothread?id=746641
https://honda-tech.com/zerothread?id=164057
https://honda-tech.com/zerothread?id=154037
Transmission - Final Drive - My Car Is Faster Than Your Car
https://honda-tech.com/zerothread?id=49597
https://honda-tech.com/zerothread?id=104535
https://honda-tech.com/zerothread?id=99400
https://honda-tech.com/zerothread?id=106959
https://honda-tech.com/zerothread?id=88381
https://honda-tech.com/zerothread?id=81221
https://honda-tech.com/zerothread?id=76843
https://honda-tech.com/zerothread?id=127118
https://honda-tech.com/zerothread?id=326440
https://honda-tech.com/zerothread?id=388328
https://honda-tech.com/zerothread?id=423862
Transmission - Final Drive - Techical
https://honda-tech.com/zerothread?id=65698
https://honda-tech.com/zerothread?id=98809
https://honda-tech.com/zerothread?id=95093
https://honda-tech.com/zerothread?id=86185
https://honda-tech.com/zerothread?id=154654
https://honda-tech.com/zerothread?id=270819
https://honda-tech.com/zerothread?id=624931
Transmission - Final Drive - General
https://honda-tech.com/zerothread?id=54834
https://honda-tech.com/zerothread?id=62446
https://honda-tech.com/zerothread?id=754589
https://honda-tech.com/zerothread?id=241652
https://honda-tech.com/zerothread?id=95895
https://honda-tech.com/zerothread?id=87475
https://honda-tech.com/zerothread?id=80676
https://honda-tech.com/zerothread?id=71737
https://honda-tech.com/zerothread?id=132767
https://honda-tech.com/zerothread?id=120769
https://honda-tech.com/zerothread?id=133670
https://honda-tech.com/zerothread?id=698279
https://honda-tech.com/zerothread?id=523752
Transmission - Final Drive - Gas Milage
https://honda-tech.com/zerothread?id=384089
Transmission - Final Drive - Other
https://honda-tech.com/zerothread?id=641533
Transmission - Final Drive - Reviews
https://honda-tech.com/zerothread?id=90310
https://honda-tech.com/zerothread?id=102379
https://honda-tech.com/zerothread?id=91196
https://honda-tech.com/zerothread?id=107134
https://honda-tech.com/zerothread?id=354337
https://honda-tech.com/zerothread?id=232253
Transmission - Final Drive - Part Numbers
https://honda-tech.com/zerothread?id=95247
https://honda-tech.com/zerothread?id=139892
https://honda-tech.com/zerothread?id=208041
Old Aug 23, 2006 | 08:24 AM
type B16's Avatar
Default Re: 3rd, 4th, 5th gearing (walker111)
i checked there but theyre all about the FD. i want to know about the actual gears or are they all the same ratio... i doubt it
Old Aug 23, 2006 | 08:28 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingb16 &raquo;</TD></TR><TR><TD CLASS="quote">i checked there but theyre all about the FD. i want to know about the actual gears or are they all the same ratio... i doubt it</TD></TR></TABLE>
Click on the link that says "gear ratio worksheet" next to it above. That topic has a link to an Excel spreadsheet where you'll find all the ratios of all the gears for all the setups.
Old Aug 23, 2006 | 08:29 AM
type B16's Avatar
dont have the program to open the file...
Old Aug 23, 2006 | 08:32 AM
cool guy name
Default Re: (kingb16)
This probably wont come out right......
Tire Diameter 22.8
Final Drive Ratio 4.928
1st Gear 3.077
2nd Gear 2.105
3rd Gear 1.652
4th Gear 1.308
5th Gear 1.033
Old Aug 23, 2006 | 08:34 AM
cool guy name
Default Re: (walker111)
Tire Diameter 22.8
Final Drive Ratio 4.4
1st Gear 3.077
2nd Gear 2.105
3rd Gear 1.652
4th Gear 1.308
5th Gear 1.033
Old Aug 23, 2006 | 08:44 AM
RagingAngel's Avatar
http://www.a-t-s-usa.com/ats-p...shtml
Yay....
Old Aug 23, 2006 | 08:48 AM
gogogomoveit's Avatar
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Tire Diameter 22.8
Final Drive Ratio 4.785
1st Gear 3.23
2nd Gear 2.105
3rd Gear 1.458
4th Gear 1.034
5th Gear 0.787
This looks like it. As far as I remember JDM gear ratio is the same as USDMs, except the FD
Old Aug 23, 2006 | 09:24 AM
1st Gear 3.077
2nd Gear 2.105
3rd Gear 1.652
4th Gear 1.308
5th Gear 1.033</TD></TR></TABLE>
This is an ATS gearset...with the only stock gear being 2nd and the final drive.
Old Aug 23, 2006 | 09:33 AM
cool guy name
Default Re: (RagingAngel)
Tire Diameter 22.8
1st Gear 3.23
2nd Gear 2.105
3rd Gear 1.458
4th Gear 1.107
5th Gear 0.848
Tire Diameter 22.8
1st Gear 3.23
2nd Gear 2.105
3rd Gear 1.458
4th Gear 1.034
5th Gear 0.787
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
My bust
Old Aug 23, 2006 | 10:28 AM
Chris N's Avatar
THE FIRST link i chose at random from walkers list HAD A LINK to a gear ratio calculator with the us ITR's gear ratios.
and im fairly certain the jdm itr ratios can be found in one of the other links he posted.
Old Aug 23, 2006 | 10:29 AM
Chris N's Avatar
Default Re: (gogogomoveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogogomoveit &raquo;</TD></TR><TR><TD CLASS="quote">.
This looks like it. As far as I remember JDM gear ratio is the same as USDMs, except the FD</TD></TR></TABLE>
No, its not. 4 and 5 are different.
Old Aug 23, 2006 | 10:34 AM
Default Re: (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
No, its not. 4 and 5 are different.</TD></TR></TABLE>
Really? Are we talking about 96 spec or 98 spec? my bad
Old Aug 23, 2006 | 10:38 AM
JDMTegraR's Avatar
Old Aug 23, 2006 | 11:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">http://www.a-t-s-usa.com/ats-p...shtml
Yay.... </TD></TR></TABLE>
**Ahem....
Old Aug 23, 2006 | 11:35 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingb16 &raquo;</TD></TR><TR><TD CLASS="quote">dont have the program to open the file...</TD></TR></TABLE>
It's an Excel spreadsheet.
If you don't have Excel on your computer, you can download a free Excel viewer from Microsoft's website. It won't let you update but at least you can look at this and any other Excel spreadsheet.
Old Aug 23, 2006 | 12:08 PM
allyourapex's Avatar
96 spec JDM and USDM are the same, (B16 ratios). 98 spec JDM 4th and 5th are longer plus the final drive.
http://hondaswap.com/reference...29132/
S80 w/LSD USDM B18C5 3.230 2.105 1.458 1.107 0.848 3.000 4.400
S80 w/LSD JDM 98 B18C Spec-R 3.230 2.105 1.458 1.034 0.787 3.000 4.785
bennyBronco
Sep 8, 2011 09:06 AM
4drITR
Jun 4, 2006 07:55 PM
Panda-san
Jun 2, 2004 07:41 PM
Cyber ITR
Dec 31, 2002 12:11 AM
Suprdave
May 24, 2002 06:27 PM
