quarter panel rust?
Old Feb 22, 2009 | 04:43 AM
cheapshot's Avatar
Default quarter panel rust?
i have some rust in typical honda section, rear quarters where the bumper mounts on, i was told that both quarters have to be entirely replaced and the guy gave me an estimate $$$$.$$ is this standard procedure, or are there other ways?
Old Feb 22, 2009 | 09:21 AM
precisionsc54's Avatar
Default Re: quarter panel rust?
if you dont want the rust to come back in a yr or so then yes I suggest a new QP.
Old Feb 28, 2009 | 11:29 AM
Neukin's Avatar
Just cut the areas out and weld in new. Depends on the area tho, usually you can bend metal as needed and weld. Then you hit with some fiberglass filler and paint to make it look stock again. It will come back through after about 3 years if on salty roads etc. I have a trick for protecting the back side and on my crx it hasnt came back through for about 4-5 years now since i fixed. If in a dry area your lucky. Fix them all the time, usually like $100 a spot, fill and prime no final paint. Depends on area and complexity of contour really. Here are some shots of one im doing now. Looks shitty now but once done you wont be able to tell. Grind welds down etc.
Old Mar 3, 2009 | 01:55 PM
dc5r2002's Avatar
i have made patches but you need to make sure you corrosion protect them properly or else its gonna come back the whole qtr panel is the way to go if its a car you plan on keeping a while.
Remember RUST NEVER SLEEPS
Old Mar 5, 2009 | 03:17 AM
cheapshot's Avatar
the body shop i went to told me that the only way they will guarantee it is if they replace the entire quarter, each quarter was about 2,000 dollars. plus the paint, labor etc. I think i was looking at 6,000 being that i need both quarters.
Old Mar 5, 2009 | 10:39 AM
baz5453's Avatar
as above as long as you cut away the bad metal and plate it like shown above their is no reason too have to re new the full quarter panels. and doing this will stop it coming back aslong as it is sealed and protected on the inside aswell
Old Mar 5, 2009 | 11:52 AM
reactone's Avatar
Welding in patches is fine, I would suggest using something like POR15 or Rust Bullet on the interior side to prevent the rust from reappearing.
Vagitarian
Paint and Body
Apr 28, 2012 12:44 PM
apexassassin
21
May 3, 2010 07:43 PM
BondoBuilder
Paint and Body
Jan 14, 2010 05:01 AM
cheapshot
Paint and Body
12
Mar 7, 2009 05:54 PM
sooo_slow
Paint and Body
May 16, 2007 09:53 PM
