advice on how to remove interior paint?
Old Feb 24, 2009 | 10:04 PM
patrickstar's Avatar
Default advice on how to remove interior paint?
ok so the previous owner painted most of the interior white. i got no idea why. but he did. the a and b pillars are white, the visors are white, and the headliner is all white. should i take em all out and use acetone and a scraper to get it off? i've seen a bunch of people talk about brake fluid, but only for plastics like the pillars right? should i do the acetone thing?
Old Feb 24, 2009 | 10:16 PM
Savegascivic!'s Avatar
Default Re: advice on how to remove interior paint?
Doesn't hurt to try a section since its coming off anyways, or why don't you just repaint it. since i don't think it will look oem after paints off
my 2 cents
Old Feb 24, 2009 | 10:49 PM
v!taminb16's Avatar
your best bet would prbaly be buying a new interior thats what i had to do all my pillars were painted a darker gray and the paint began to peel then i tried sandin it of didnt work made it worse then i just started chipping it off with my nail took forever so i decided to throw it away and get new one's
Old Feb 25, 2009 | 03:47 AM
JScott3d's Avatar
on some of it you can use aircraft stripper. I have done it a few time and never had a problem just try it in a hidden area first. It will eat some plastics just not all.
Old Feb 25, 2009 | 09:03 AM
hmm alright ill just peeling it off and see what happens. it just crackles. where do you guys suggest buying oem interior? like any websites besides craiglist and ebay. and what should i do with the headliner? can i use aircraft cleaner as well?
Old Feb 25, 2009 | 10:00 AM
JDM 98 GSR's Avatar
if you want black interior just buy the SEM coat landua black paint and reparint it all. that paint does wonders and matchs oem interior
Old Feb 25, 2009 | 01:08 PM
v!taminb16's Avatar
no no noooo not use aircraft paint remover that will mess you all up
Old Feb 25, 2009 | 09:35 PM
hmm thinking about doing this. so do i just sand it down and repaint? or will sanding it down make it worse?
Old Feb 26, 2009 | 04:10 AM
JDM 98 GSR's Avatar
clean everything with degreser then sand it with a scuff pad, then use a plastic adhesion promoter, then paint. if you do that nothing will chip off or scratch. the prep work is they key to making the paint last
Old Feb 26, 2009 | 10:49 PM
oooh thanks for the advice. can i find all of this in a walmart or something?
Old Mar 3, 2009 | 01:58 PM
dc5r2002's Avatar
try using laquar thinner its what they clean paint guns out with its harsh so whipe it of quickly then wash the parts off with some soapy water
Old Mar 5, 2009 | 09:42 AM
dangmedcalf's Avatar
I found the SEM paint at Napa, just call and ask, its about 11 dollars a can. if you decide to to repaint everything after taking the paint off id use that
jason_v2
Paint and Body
Feb 22, 2009 06:13 AM
redlinin
Mar 13, 2007 12:22 PM
akcivic-teg
Jan 6, 2003 09:05 PM
charjacq
Dec 19, 2001 09:12 PM
Dido-Motosports
Dec 18, 2001 01:41 PM
