paint compressor minimum psi
Old Feb 17, 2009 | 11:51 PM
allshownogo's Avatar
Default paint compressor minimum psi
On average for a hatch it takes about 10 minutes to pass a full coat. with a compressor at 45psi I should be able to pait a car at what cubic foot per minute do I need for a compressor? in other words I shouldnt need a $500+ compressor should I? at sears what will throw a decent coat of paint on a hatch with good body work on some what of a budget. and give me a preferable temp range for the booth. garage paint with a **** load of flourecents and heaters+exhaust fans.
Old Feb 18, 2009 | 12:54 AM
slimgsr's Avatar
Default Re: paint compressor minimum psi
Different guns will require different cfm. My HVLP uses 14cfm but, I've seen several guns only need 9-11cfm. I've primed with a smaller compressor and was waiting for it to keep up quite a bit. You could compensate by using a slower reducer though. Good luck!!
Slim
Old Feb 18, 2009 | 02:48 AM
IMPATIENT's Avatar
cfm is your biggest concern . you can have 10000 psi but if the cfm rate of the compressor isnt enough,your gun will suck it dry. you should be looking at getting a compressor with at least 12-14 cfm.
Old Feb 18, 2009 | 04:49 AM
cool thanks guys!
Old Feb 18, 2009 | 09:07 AM
93monsterbubble's Avatar
what ever you do get a good water/oil seperator and make sure your compressor is not going to be starting stopping in the middle of spraying, this will raise and lower your pressure at the gun and change the way you're atomizing the material. it looks like *** if you have this problem and you;ll have fish eye problems without a good seperator
92civicx
Paint and Body
Feb 6, 2009 08:45 AM
Joe-G
Paint and Body
Aug 25, 2008 12:26 PM
K20A_EH
Paint and Body
May 23, 2007 12:15 PM
K20A_EH
Welding / Fabrication
24
May 16, 2007 02:40 PM
pootie.teng
Apr 8, 2004 09:19 PM
