body work???
Old Feb 2, 2009 | 01:55 PM
EGKREW's Avatar
Default body work???
what kind of sand paper i get to sand the bumpers and the body with to get it ready to fill in the dings and dents. and what is agood brand to fill those in with?
Old Feb 2, 2009 | 02:16 PM
EGKREW's Avatar
Default Re: body work???
help me out
Old Feb 3, 2009 | 06:52 PM
ek_bape's Avatar
I would like to know also
Old Feb 3, 2009 | 09:01 PM
mfef4dr's Avatar
I use this stuff . Its a flexing filler
Heres another type
http://www.carpaintdepot.com/proddet...?prod=SEM39492
Old Feb 3, 2009 | 11:40 PM
prelude1897's Avatar
I usually use 80grit to get the deep scratchs out, then go back over with 180 grit to smooth it out, then spray some 2k urethane primer, lightly sand that with 320 grit to get any trash out, then wet sand with 600, then paint it. Just be sure you get sand paper for cars, not wood. When I fill in spots after I've shaved a bumper or fix something, I'll use body filler first, then use that glaze to fill in any imperfections.
Old Feb 5, 2009 | 06:40 PM
EGKREW's Avatar
if i just use the bondo and spray over it can you tell a lot on the inperfections???
Old Feb 5, 2009 | 06:53 PM
EGKREW's Avatar
is this good to use for the bumpers and the body??
Old Feb 5, 2009 | 09:12 PM
EGKREW's Avatar
help me out
Old Feb 5, 2009 | 09:37 PM
h22ej8's Avatar
Good for body, not for flexible bumpers. It'll likely crack/fall apart unless you're just doing rock chip repair with it (not really the right way to do it, but a hell of alot easier/less time consuming)
Old Feb 6, 2009 | 08:38 AM
EGKREW's Avatar
whats good for bumpers??
Old Feb 7, 2009 | 10:22 AM
EGKREW's Avatar
this is what i got so far
Old Feb 7, 2009 | 10:23 AM
EGKREW's Avatar
how should i sand this down?
Old Feb 7, 2009 | 03:36 PM
precisionsc54's Avatar
its called dont bother. Just get a new one aftermarket for about $65
If you do insist on fixing that. I would suggest not using Bondo brand bondo its garbage. Go to and autobody supply store ang get some Upol Body filler or some Rage Gold. After that go over it with some Dolphin glaze.
Old Feb 8, 2009 | 03:54 PM
EGKREW's Avatar
that stuff works good on bumpers? how would i sand it down
Old Feb 8, 2009 | 05:57 PM
Use some good 180 then gradually work up to higher grits. Yes it works fine
Old Feb 8, 2009 | 06:37 PM
lilshady6796's Avatar
no you really should use a plastic bumper repair kit -3m- makes it and it works great my auto body shop had a demo on that ****
Old Feb 9, 2009 | 06:36 AM
ya the plastic repair kit by 3m is good if you have a rip or something. Just to fill minor imperfections regular body filler is fine. I have done it hundreds of times with no problems in the long run. The key is prep work make sure you have a rough surface so the filler has something to bite into.
Old Feb 9, 2009 | 01:09 PM
mztykal's Avatar
I use Rage Extreme on bodywork and Polyflex on bumpers.
I've used Rage Gold on bumpers and it's been fine for years on a few friends cars.
Sand down the paint with 80 grit before applying the filler on the body. Never hit your bumper with anything rougher than 80 grit before the filler and after nothing lower than 180.
Old Feb 9, 2009 | 02:05 PM
Exactly
Old Feb 10, 2009 | 10:26 PM
gorillafart's Avatar
if u got money... get zebra by 3m or z-grip premium filler by evercoat... kinda pricey but its the good stuff... better then rage gold... (rage gold is made by evercoat also)
bondo usually goes on bare metal/plastic. but with new formulated filler's today such as zgrip, u can put on painted surfaces...sanding down to the paint and starting from there.
but whatever bondo you're using here... i'd sand lightly with 80 then move to 120-150 and finish with 220 to feather edge and/or remove any of those 80 and 120-150 grit scratches... letting the sandpaper do its work... not pushing hard against the bumper.
use primer surfacer and boom paint it.
-in a nutshell.
Old Feb 10, 2009 | 11:17 PM
mztykal's Avatar
-in a nutshell.
Dude, learn your products before you go spouting off stuff. Z-Grip is their economy line of filler.
Old Feb 11, 2009 | 04:03 AM
Z-Grip is garbage @ $8.00 a can I bought like 20 cans to use on some fiberglass projects I was involved with. Let me tell you its not worth them giving it to you for free.
Rage Gold is over $30 and worth every penny
Old Feb 12, 2009 | 04:23 AM
mztykal's Avatar
I prefer Xtreme Rage.
Sands smoother with less pinholes.
duh702dc2
Paint and Body
May 10, 2014 11:43 AM
dvs94Teg
Paint and Body
19
Nov 13, 2010 08:59 AM
serious
Dec 12, 2002 02:07 PM
integration
Sep 22, 2002 10:25 AM
entityhatch
Jul 21, 2002 01:30 PM
