Honda S2000 Honda S2000
Sceetch when turning left.
Old Jul 24, 2009 | 04:54 PM
Status R's Avatar
Default Sceetch when turning left.
I have a 04 s2k with 64k miles on it. I noticed today then when i make left turns, at any speed, I have a decently loud screetching sound comming from what seems to be my front right wheel area. It does it when i drive rough or calm. It doesnt click and it does do it sometimes. It's constant whenever im making any amount of a left turn, and its always a solid screetch noise. Any suggestions?
Old Jul 25, 2009 | 10:31 AM
Status R's Avatar
Default Re: Sceetch when turning left.
update: i check it out today and nothing seems out of the ordinary. The car doesnt make the noise in reverse, only while moving foward. At any speed, and still only while turning any amount to the left. It is def. comming from the front right wheel.
Old Jul 27, 2009 | 07:21 AM
White Smoke's Avatar
i my honda
Global Mod
Have you had the car aligned? That's where I would start... It probably needs to be done anyway.
Old Jul 27, 2009 | 07:06 PM
Targa250R's Avatar
be professional
It's probably the squealer tab on the worn out brake pad contacting the rotor . . .
Old Jul 27, 2009 | 07:10 PM
green-'s Avatar
Or the squealer tab on the worn out rotor contacting the brake pad.
Old Jul 28, 2009 | 04:59 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
yeah i agree with the squealer... if it starts happening all the time instead of just left turns then its your brakes... you can either remove the squealer tab or replace your pads completely... and if u have an AP2, i suggest you get AP1 brake pads... even though they dont bite as well, the brake dust is significantly reduced... ohhh and if u do decide to remove the squealer, depending on how you drive, youll have only a few hundred miles before the brakes are completely shot...
Francis N
Honda Civic (2001 - 2005)
Sep 21, 2015 06:26 AM
scuzzi
Nov 5, 2012 07:53 AM
lJakel
Jul 16, 2012 07:25 AM
FTNW
Jul 7, 2012 04:32 PM
