Honda S2000 Honda S2000
CEL back
Old May 7, 2009 | 06:55 AM
TypeR324's Avatar
Default CEL back
So yesterday on my way to work my CEL came on again. It came on less than a month ago when I had three of four cylinders misfire https://honda-tech.com/forums/honda-s2000-5/cel-%3D-misfire-my02-2544062/. I replaced all the plugs and all was fine until yesterday. I checked the CEL and it was a P1399, and P0304, I was concerned that the top electrode had broken off again. When I left work my CEL didn't light up again, I am very confused as I have never seen the CEL stay on for a few hours then turn off. When I got home I checked cylinder #4 (nearest to the firewall right?) which had the misfire and the plug looked fine. I then started to think that it may be the ignition coil but I replaced that coil May of 08'. I ended up switching the #4 coil with the #1 coil. So far today the CEL is still off, anyone have any advice on this one? Thanks.
Old May 8, 2009 | 01:30 PM
TypeR324's Avatar
Default Re: CEL back
So after driving around for two days probably 100 miles or so the check engine light is still off. I was hoping it would come back on so I could see if the problem was the coils. The car however does feel slugish I only went past 6k rpms once or twice and vtec does not feel normal. I'm going to do a compression test this weekend. So is it normal for a CEL to stay on for 50 miles then just turn off?
6KAOS6
Jun 4, 2011 05:55 AM
TypeR324
Honda S2000
17
Apr 15, 2009 09:42 AM
harlen
Feb 19, 2008 05:31 PM
Flava
Aug 4, 2006 12:58 PM
raCeRX_88
Nov 22, 2005 06:06 PM
