where is the turn signal relay located?
I cannot find where the turn signal relay is. Mine went out, and I cannot find where it is located. Please let me know, thanks!
i ♥ my honda
Global Mod
Global Mod
Re: where is the turn signal relay located?
Are you sure your relay went out? What's the problem you are having?
I attached the relay location, it's found inside the car with the rest of your fuses.
i ♥ my honda
Global Mod
Global Mod
I'll give you the most common problem for your turn signals not working... The hazard's switch is not plugged in.
Let us know how it works out
Ya i bought another OEM turn signal relay, and it didnt look like the one on the car, so that confused me. Yup anyways, i did mess with the console before the turn signals went out, and i did plug the hazard switch back in. I just took the console apart again and just made sure the hazard plug was in all the way and it all works now! Thanks for the help
the "clicker" sound is almost absent when the turn signal is switched on, either right or left. All bulbs, front and rear and right and left all light up when activated. Is the lack of noise a turn signal relay fault?
Phrog
01-31-2014 01:12 PM
jayputelis
09-25-2004 09:00 PM
