Honda S2000 Honda S2000
Engine bore and deck height
Old Mar 6, 2012 | 04:48 AM
Importracer_001's Avatar
Default Engine bore and deck height
Hi Guys,
I'm having a problem with my F22C engine, it's mixing engine coolant and oil after it overheated. I've tried to fix this by changing the headgasket, head and engine deck straightness was verified with a straight edge.
I think that my cylinder head might be damaged or cracked causing the coolant and oil to mix.
Do you guys know by any chance if the F20C and the F22C engines have the same bore size and deck height?
Would I be able to use F22C internals (crank, rods and pistons) in a F20C engine?
Old Mar 6, 2012 | 06:55 AM
beandip's Avatar
Default Re: Engine bore and deck height
Originally Posted by Importracer_001
Hi Guys,
The F22c had a longer stroke, so no the deck height wont be the same.
http://en.wikipedia.org/wiki/Honda_F20C_engine
Old Mar 6, 2012 | 07:26 AM
The article doesn't mention anything about the deckheight.
Kind of like the B18C and B18B engines same deckheight but different stroke makes up for the B18B's larger displacement.
Old Mar 6, 2012 | 07:51 AM
Boots's Avatar
F20 and F22 have the same blocks...its the internals that vary
Old Mar 6, 2012 | 08:58 AM
That's good news.
Jon Petersen
20
Apr 12, 2019 03:29 PM
devin0606
Mar 21, 2017 12:45 PM
AccordInTheMaking
Jan 4, 2009 07:58 PM
hkboy87
Oct 9, 2008 10:53 AM
ylfotevoli
Apr 30, 2007 07:00 PM
