Honda S2000 Honda S2000
help on getting hot
Old Oct 2, 2011 | 01:53 PM
civicracer94's Avatar
Default help on getting hot
need alittle help with my S ..ok so its building pressure and gettng hot ..it dont show to be hot on the gauge..the top hose is hot but the bottom hose is cold also my heater does not get hot..not even warm ...i just replaced the thermostat.. and still the same thing ..could the waterpump be bad ? its not leaking and theres no noise coming from the pump
Old Oct 2, 2011 | 05:28 PM
Boots's Avatar
Default Re: help on getting hot
sounds like you have a restriction somewhere
Old Oct 2, 2011 | 06:24 PM
luvmihatch's Avatar
time for a koyo radi and some samco hoses.
problem solved.
Old Oct 3, 2011 | 06:20 AM
yea thats what i done i put a Mishimoto on it and its been getting hot every sence..im pretty sure i have air in the system but i cant seem to bleed it out
Old Oct 3, 2011 | 11:16 AM
luvmihatch's Avatar
its bc u need pressure on the system. sitting there waiting for the bubble to come isnt gonna do ****..
this is what u need.
http://media.photobucket.com/image/r...-15-30_217.jpg
it lets u build the pressure needed and "over fill" the system. u put this on your radi. full the funnel up about half way and as it warms up. cycle the heat give it a lil gas and it will suck the bubble out. takes about 30 mins. i had todo it to my 2010 pathfinder bc the heat wouldnt work at idle.
pm me with any questions.
Old Oct 3, 2011 | 11:56 AM
95 integra's Avatar
How long did you run it for? The top hose is the return and the bottom is the feed correct? It's normal for the feed to be much cooler than the return as the radiator has cooled the coolant by the time it reaches the bottom hose. What is "hot"? I mean, an engine normally runs at 180-220 degrees, so ofcourse it's "hot". As far as heat goes, you need to properly bleed the system and get coolant into the heater core, which sounds like its your problem...not sold on the cap with the funnel on it....somehow I've done 20 cars without ever having one of those...
Old Oct 3, 2011 | 12:24 PM
luvmihatch's Avatar
obviously, you can burp a system with out this method. its just an idea. he obviously has a bubble in the system and as u said needs to get coolant in the heater core.
another thing he could try is to manualy open the heater control valve near the fire wall. and see if its stuck closed. ive seen that b4 too.
Old Oct 3, 2011 | 03:32 PM
Boots's Avatar
yup, i have the 50 dollar snap-on one....i hate the snap-on man
Old Oct 3, 2011 | 05:54 PM
dagle's Avatar
park your car on a steep hill (nose pointing uphill of course), pull the cap off but be careful if you just turned the car off and it hasn't cooled, fill to the top and close the cap. start the car and let it idle until the fans come on or hold it at 3k until the fans come on. Afterwards, with a rag or something (folded 4-5 times over so it's 1" thick) turn the pressurized cap off a quarter turn. you'll hear air hiss out and coolant will be trying to flow out. Turn it back and you'll have 90% of the air out of the system. Let the car cool down so the coolant can contract, top it off and you should be good.
Reason it isn't overheating is probably because there's enough coolant in there for the fans to pick up the slack. good luck
Old Oct 4, 2011 | 05:57 AM
apwhat's Avatar
great thread, you can also release the bleeder valves right? i forget where there located but i know its for removing air bubbles..
anther thing, my top hose is red hot, litterly bakes the engine.. is this normal? should i take a temp reading.. just feels way too hot
Old Oct 4, 2011 | 09:22 AM
luvmihatch's Avatar
do u have the part number for that. mine is home made, but it works.
and i love my snap on man, my wife doesn't tho lol.
Old Oct 4, 2011 | 09:23 AM
luvmihatch's Avatar
nah it shouldn't be that hot.
Old Oct 4, 2011 | 11:15 AM
95 integra's Avatar
Red hot? Bakes the engine? You need to be more specific....as I stated, your engine normally runs at 180-220 degrees....which is HOT...like throw a steak on type of hot. It shouldnt be "red hot" but I doubt anything on your engine is glowing red...and if it is, I take my all my remarks and you've got real issues.
On a side note, I'd like to see pictures of it being red hot....I mean, I've seen racing engines with red hot headers and rotors that are red hot, but nothing on a street car.
Old Oct 6, 2011 | 02:07 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
yup u need a giant yellow thing to fix ur problem lmfao
vsikwit
Aug 15, 2010 01:15 PM
KYLE.ECKERT
Jan 20, 2009 08:43 PM
darkblackH2B
Dec 15, 2008 07:08 PM
Widebodys2k
Honda S2000
Dec 5, 2006 04:49 PM
hondaricegirlz
Jul 17, 2004 06:52 PM
