Honda S2000 Honda S2000
sagged shift boot
Old Oct 18, 2011 | 04:21 PM
Bright13's Avatar
Icon6 sagged shift boot
I've owned my S for a few months now and keep putting off fixing my shift boot. When I bought it used from a Honda dealership it had several of the optional accessories, including the "titanium" shift ****. However the boot was not secured beneath the **** and falls about half an inch below the shift **** exposing the nut. finally today I got around to giving it a closer look, and as obvious a problem as it seems I can't figure it out. the boot I assumed just wedged between the nut and the ****, but that doesn't seem the case. How do I fix this?
Old Oct 18, 2011 | 05:21 PM
Black S2K's Avatar
Default Re: sagged shift boot
thats how it is. there is nothing wrong with ur boot. it does not come secured to the shift **** or the nut under it
Old Oct 18, 2011 | 06:09 PM
Bright13's Avatar
So it just kinda hangs there, with the shifter exposed unlike other cars? I guess because it doesnt slide overly far down like in other vehicles it makes it acceptable, but still wierd
Old Oct 18, 2011 | 06:47 PM
postman's Avatar
if you really want a trick i have used in the past is to use a large rubber band around the shifter. this helps hold the boot up in place and is adjustable kind of.
Old Oct 18, 2011 | 07:42 PM
bigmacnfries's Avatar
^^ i must do this - saggy boots are no good.
Old Oct 19, 2011 | 12:40 PM
postman's Avatar
yeah it works pretty well. i should patent it for honda.
Old Oct 29, 2011 | 10:01 PM
Rtzx9r's Avatar
GDD 1%
As our cars age they tend to get saggier boots
Old Oct 30, 2011 | 03:10 PM
bkowa092's Avatar
I put washers on the shifter itself. I removed the ****, squuezed the washers inside the shift boot opening, and now I have no more sag.
There was also no sag with the stock shift ****. However, I didn't take a picture before installing this one.
toshko321
10
Oct 5, 2009 08:21 PM
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
tnewhallSi
Mar 31, 2006 11:44 PM
pre1udekid
Jul 12, 2004 03:49 PM
M0NEYnH0s
Feb 4, 2002 07:04 AM
