Honda S2000 Honda S2000
s2000 engine in to....
Old Mar 11, 2012 | 09:20 PM
slo89notch's Avatar
Default s2000 engine in to....
so i've been considering an engine swap using an fc20 or fc22 engine
for 3 simple reasons
1-amazing engine and gearbox with plenty of power for the weight and wheelbase of the car i intend to put it in
2- to **** everyone off (the muscle car haters and the import haters at the same time)
3rd and most important it's different than i've ever seen before!
so here's the idea
s2000
curb weight 2800lbs give or take a few
wheelbase 94.5 inches
the car im talking about swapping the engine in to is a 1989 ford mustang notch
it's the lightest mustang combination i know of (2600lbs as it sits right now, with the stock 88hp 2.3 and 5speed trans and 1/4 tank of gas)
and the wheelbase is 100.5 inches
taking things to basics the car's arent to different size and weight speaking
i've been thinking of a 2.3 turbo engine in to the mustang because it'll bolt right in and be done, but thats to easy and if i do that i get **** from the muscle car guys that even tho im faster with a 4cyc that it's got a turbo and that it's not a v8, and i'd get **** from the import guys because my turbo 2.3 making 190hp stock is about the same as a b18c na
so i figure fc20/fc22 and 6speed in the mustang would be a great combo
to show everyone up
and even beyond what everyone thinks it's undeniable that it's something completely different
and i honestly think it would be a fun *** car to drive after doing the swap
and i think it would shock alot of people to see whats under the hood
or hear the exhaust when i start it up or drive down the street
don't want to make it a race car (yet) just something fun to drive on the weekends
so what do you think, i know it "can" be done but lets be serious howmuch do we think will be involved? i mean the engine bay was made for a v8 so even with the stock 2.3 theres enough room for someone to stand on either side of the engine and in front of it so i don't think room will be a problem
and getting a rear gear to match the engine/trans combo won't be hard because there is a huge aftermarket for the ford 8.8 rearend and it can take alot of abuse without a problem
the only thing i think will be difficult will be engine management
and if the engine is to tall either a cowl hood could cure the clearence problem or leaning the engine slightly to lower it just like in some straight 6 bmws
ok i guess let the flaming begin!
Old Mar 11, 2012 | 09:42 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
Default Re: s2000 engine in to....
good luck have fun be safe !
Old Mar 11, 2012 | 09:50 PM
HondaKyle's Avatar
ls1 swap it.
Old Mar 11, 2012 | 10:01 PM
Boots's Avatar
i hope you know how to fabricate and have the means to do so
Old Mar 11, 2012 | 11:43 PM
slo89notch's Avatar
wow thanks for the semi-positive response (maybe it's just sarcasm and im dumb but hey i'll take it)
and
;hondakyle- it would probably be cheaper and faster but, pushrod v8 in a mustang...
just not feelin it
;boots- yes i do
and long story short i'll do a build thread on the project if yall would like
but i ain't going to lie it's not going to be a quick month long build or anything
i have a dd this will be my toy, if i have it up and running in 6months cool
if it takes 2-3 years to get it done right then so be it, know what i mean?
but first things first
drivetrain
should i just buy an engine and trans
or should i find a totaled s2000 to use all i can from it and ebay the rest?
Old Mar 12, 2012 | 12:18 AM
DCRB's Avatar
first off i'll say that i don't own an s, so i don't know what is hot and what is not when it comes to parting one out.
however from the various swaps i've seen done from s2k's into corollas and what not its alot easier on the swap part to pick up the full car, so you can look at factory fitment in both vehicles. also having a parts car to part out would be benifical for fundage
as far as engine management goes, you can probly use the stock s2k ecu? i saw a thread where some one took apart the whole body/engine harness for swapping the motor into their corolla, and it had like 5 wires that went from ecu to the chasis everything else was strait to the motor.
i think the biggest things you'll have to tackle are motor/shifter placement, don't know how the honda trans is different from the ford one, and cluster set up. will you use the stock ford, the s2k, or go full aftermarket?
drive shaft should be easy, measure distance from the pumpkin to the output shaft on the trans (or whatever they're called) once motor is fully installed and running, and then have a custom one made with ford rear u joint and honda front i would assume.
Old Mar 12, 2012 | 01:06 AM
slo89notch's Avatar
i'll have to do some digging, if i can keep the factory ecu that would save alot of $$ especially with the reliability of factory tuning ect. ect.
as for shifter placement and such im searching right now to see exactly how far it is from motor mount to shifter but i figured if it was a little long or short of stock placement (+/- 4inches i could make a shifter to compensate)
as for the cluster i'd like to use the s2000's cluster (just because i think it looks cool) but otherwise i might have to go aftermarket (mustang guages only go up to 6000rpm and 85mph even the cobra guages only go to 7000rpm but to 140mph) haven't looked to far in to guages yet figured the big stuff would come first and the guages and such would come around as things come in to place to button things up
when it's all done i want it to have a stance similar to this one
http://classic-ford.org/forum/upload...301540_fox.jpg
just not that low maybe 1.5-2inches higher and level, that one the front looks a hair lower than the rear
Old Mar 12, 2012 | 01:07 AM
dagle's Avatar
Honestly probably much better off with a V8, the S2000 motors are impressive in their own rights, but displacement is a huge advantage. If you like the powerband of the S2000, by all means, but if you're mainly looking for fun and drivability with no sway towards any build in particular, the LSx or another viable V8 swap would probably be the way to go. At the end of the day you're thinking about putting a 200whp motor into what will be a 2800-3000 pound car. Far from impressive in my opinion, but it might be a lot of fun ringing it out so it's up to you. Good luck
Old Mar 12, 2012 | 01:35 AM
slo89notch's Avatar
i agree with you 100%
but i do really like the powerband of the s2k's f20 engine
and balance and weight is a large factor
i plan to do an occasional track day
i know a fc20 will last a long time spending 30minute sessions at 6-9k rpm
i'd be worred with an ls1 even thats built to rev to 7k rpm wringing it out from 4-7k all day reliability is a large factor
but honestly the biggest factor is just being different
i mean how many ls1,bbc,bbf,sbc,sbf,ext. ext. mustangs are out there?
even the 2.3turbo even seen a couple with the 3.0l sho v6 in it
but never seen a honda engine in a mustang
and i really think it will **** off alot of the dumb "it's gotta b a v8 or it can't be fast" rednecks
i know the wheel has been perfected no need to reinvent but maybe theres room for adjusting u know?
plus i figured stock (well boltons) for a while but eventually a good supercharger setup and 350-400whp on pump gas nothing crazy (prefer turbo but for trackdays the smooth power delivery of the supercharger would me much more user friendly than a turbo deciding it's time to spool mid corner....)
Old Mar 12, 2012 | 11:20 AM
HondaKyle's Avatar
A ls1 weighs 50 pounds more then a F20/22.
Old Mar 12, 2012 | 11:31 AM
Dc4LsTeG's Avatar
EK9
If your gonna put that motor in it you better turbo it
Old Mar 12, 2012 | 02:05 PM
MikeB18c's Avatar
Sounds like that will be quite the project. I don't think you'll get anywhere near the torque you will want for a muscle car.
Old Mar 12, 2012 | 04:25 PM
JUSTINTHECOASTI's Avatar
Boost it or swap in a v8
Old Mar 13, 2012 | 06:27 PM
slo89notch's Avatar
your comment proves the exact point of the build
take the name off of it and based on weight an dimensions
my mustang is extremely close to the s2000
i think the mustang is actually about 200lbs lighter as it sits
and the wheelbase is about 5inches longer
as for the torque... right now it's got 88hp and 100ft-lbs on a good day
so
im sure it's not going to be that much slower with 153ft-lbs
oh and about 180 more hp....
but the car is not going to be a straight line queen it's a weekend cruiser that'll see track days here n there
Old Mar 13, 2012 | 06:29 PM
TheMuffinMan's Avatar
He knows where you live!
so
What is the Mustang's f/r balance? I've got a feeling it's not 50/50. So just because it weights like an S2000 does not mean it will handle or drive like one...
Old Mar 13, 2012 | 07:29 PM
Boots's Avatar
no, no its not
Old Mar 13, 2012 | 08:23 PM
Arsenal's Avatar
Does not compute...
Old Mar 13, 2012 | 08:57 PM
slo89notch's Avatar
never said or implied that
i have alot of suspension work ahead of me but, this is a discussion about the engine swap
not making it handle like the car the engine is coming out of
as for the question of balance as it sits right now it's right at 56/44
but just like the comment you made about handling
i've got it covered
im simply hear to gauge how people would react to see such an engine transplant
you can rest assured when it's all said and done it may have the same engine as your car but it will be faster and handle better
Old Mar 14, 2012 | 03:27 PM
eastcoastbumps's Avatar
Sounds like a cool swap. You should go for it.
Originally Posted by Boots
no, no its not
You either know nothing about S2000's or nothing about Mustangs.
Old Mar 14, 2012 | 03:42 PM
Boots's Avatar
i hope that was sarcasm...
Old Mar 14, 2012 | 08:14 PM
fknfast's Avatar
the craze over here where im at is a 4g63 in notchbacks..............i personally wouldnt put a Fseries in a ford
Old Mar 20, 2012 | 09:39 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
OP: It sounds like you just want a project in order to do something different. I can't seem to quantify the cost vs. benefit of this swap as being any good, however.
That's a good amount of welding and fabricating. As well as a custom driveshaft...as well as wiring, tuning, etc. etc. etc. All for 240hp and 153lbs of torque? Meh.
Honda engines aren't exactly cheap either compared to their domestic counterparts. An AP2 full swap sets you back between $3500-4000+.
But if it's just the thrill of the project that you're after, then it might work out for you.
Old Mar 22, 2012 | 01:50 AM
Sarnacus's Avatar
Don't do it!
Bozwell
Classic Hondas
380
Jul 15, 2012 10:36 AM
Charlie Moua
Honda S2000
59
Mar 21, 2010 01:20 PM
djnikko
Honda S2000
May 7, 2006 01:14 PM
magic15x
Honda S2000
29
Oct 31, 2004 05:46 PM
5150CRX
Honda S2000
Apr 9, 2003 11:43 AM
