Lighting HID/Xenon kits, Retrofits and Associated Topics
tail light indicator on guage???
Old Jul 22, 2008 | 04:35 PM
boarding2008's Avatar
Default tail light indicator on guage???
i have a 92 accord and under the fuel/temp guage there is a icon that shows if a door/trunk is open and under that it says taillight. well i goes on every so often so i check my tail lights and brakes and they all work and are fine and then it will go off when i turn the car off and then back on. Any ideas on why,my guess is one of the fuses Thanks in advance
Old Aug 1, 2008 | 07:15 AM
xXx Justin xXx's Avatar
Default Re: tail light indicator on guage??? (boarding2008)
recently replaced any bulbs? might have a slightly different voltage or amprage than the other bulbs. i have seen some WILD things happen with honda's all b/c of a bulb (correct # bulb and everything) being a different brand and slightly different wattage or amprage.
Old Aug 1, 2008 | 10:49 AM
TunerN00b's Avatar
I've seen that happen when the 3rd brake light isn't securely mounted. Bumps ion the road, or slamming the door closed, moved it enough to trip the light momentarily.
Not sure if that helps any.
Old Aug 3, 2008 | 11:01 AM
Default Re: tail light indicator on guage??? (xXx Justin xXx)
no i havent replaced any tail lights recently. i did replace my driving light on the passenger front but it is the correct wattage and everything. ill check if the 3rd brake light is secured. thanks
raffydogg
Lighting
Mar 23, 2008 11:53 PM
raffydogg
Mar 21, 2008 06:32 PM
npetro1
Feb 7, 2008 06:05 PM
4npower
Sep 27, 2007 08:33 PM
thn116
Aug 12, 2007 07:14 PM
