Lighting HID/Xenon kits, Retrofits and Associated Topics
NEED HELP WITH H3 BULBS!!!
Old Jun 2, 2008 | 09:30 PM
98savage's Avatar
Default NEED HELP WITH H3 BULBS!!!
So I just put in my JDM CC2 one piece headlights today...they use an H3 foglight. Same thing my USDM headlights used. Only thing is, the wire coming off of the JDM bulb is different than the USDM bulb!! All I can find at the store are the H3 bulbs with a SPADE connector on the end. These have a ROUND POINTY connector on the end...I don't know what you'd call it! Spades will NOT fit in the JDM wiring harness. Ebay doesn't have anything except the spades.
The bulbs look to be original...they are Stanley bulbs. 35watt...USDM H3 is 55watt...that's all I can find.
Old Jun 4, 2008 | 04:36 AM
operatic's Avatar
Default Re: NEED HELP WITH H3 BULBS!!! (98savage)
If you can post a picture I bet I can help ya out
Old Jun 4, 2008 | 03:01 PM
DDEVIANT1's Avatar
European H3 bulbs have the round end too, either make a jumper wire like 1 inch long with a female spade and a male bullet or get some european bulbs...PG performance sells the european H3 bulbs.
Old Jun 4, 2008 | 06:02 PM
98savage's Avatar
Default Re: NEED HELP WITH H3 BULBS!!! (DDEVIANT1)
All I did was cut off the wire from the bulb with the bullet on the end and crimp a female spade onto it...then plugged in the spade H3. Worked like a charm...fixed it last night. Thanks for your help though...
.joeham
Lighting
13
Dec 7, 2007 01:28 AM
KageOokami
Aug 30, 2006 09:52 PM
Slava.
Jul 7, 2004 02:49 PM
bokguay
Jan 30, 2004 08:22 PM
philipwight
12
Aug 27, 2003 04:03 PM
