Lighting HID/Xenon kits, Retrofits and Associated Topics
Electrical problem
Old Sep 13, 2008 | 11:57 PM
JDM.DEEBO's Avatar
Default Electrical problem
thanks guys
Old Sep 14, 2008 | 11:35 AM
JDM.DEEBO's Avatar
Default Re: Electrical problem (JDM.DEEBO)
can someone help me?
Old Sep 14, 2008 | 12:43 PM
E.Honda's Avatar
bad ground
Old Sep 14, 2008 | 01:49 PM
DHutch's Avatar
Default Re: Electrical problem (E.Honda)
I have this exact same problem ... how do I check out the ground ... I can't find a good headlight wiring diagram
Old Sep 14, 2008 | 02:15 PM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
your ground for the head lights should be with that harness you dont need a wiring diagram just look at the harness and their should be a little box with a whole bunch of black wires those are all your grounds and you bolt that down to the chassis and to test the ground just use a DMM and it should read around .01 of a volt or so and if it reads higher then there is resistance and should probably reground or clean up grounding area GL man!
Old Sep 14, 2008 | 11:04 PM
JDM.DEEBO's Avatar
Default Re: (Jdmsoles)
thanks everyone fix my problem. it was my grounding.
Old Sep 15, 2008 | 07:55 PM
JDM.DEEBO's Avatar
Default Re: (JDM.DEEBO)
im havinng another problem now!
Old Sep 16, 2008 | 12:42 PM
JDM.DEEBO's Avatar
anybody?
Luke G.
Sep 25, 2009 07:55 PM
Pro-lite
Aug 28, 2006 07:31 PM
fcrx7zoomzoom
Jun 14, 2006 08:35 PM
