Lighting HID/Xenon kits, Retrofits and Associated Topics
Question about hard wireing an hid kit
Old Aug 30, 2008 | 04:41 PM
chairwitharmrests's Avatar
Default Question about hard wireing an hid kit
Ok so I got this kit from a friend
But the connector that "connects to stock harness", has been cut off. (Why I do not know) So how can I go about installing the kit? Can I buy the connector from somewhere? Then I was thinking about hard wireing it, but the stock connector consists of 3 wires, where as the mcculoch connector only has two wires.
Old Aug 31, 2008 | 11:34 AM
OMG THE GOGGLES's Avatar
Default Re: Question about hard wireing an hid kit (chairwitharmrests)
https://honda-tech.com/zerothread?id=2012150
You can just wire it to the headlight, tap into it instead if you want, or buy a broken HID kit and resolder the ends on
Old Aug 31, 2008 | 11:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Your car has dual-filament H4 headlights (1 wire each for low and high beam and 1 ground wire). The HID ballast and bulb is low beam only, so you would have to wire it to the low beam wire on each side. Use a multimeter to figure out which wire is which.
But now you won't have high beams (illegal) and if you accidentally flick the high beam switch, the low beams will shut off.
And you'll be putting out made glare all over the place, because PnP HID kits suck ***. Period.
Old Sep 1, 2008 | 09:39 AM
will, I be fine hardwireing the kit in the way it is? Or do I need one of those relay harness things?
The pic in that link, looks like it has alot more going on then my kit, as far as the fuses and haveing to connect to the battery.
Btw this is going in my 4runner not my civic, but the 4runner is also h4.
Old Sep 2, 2008 | 08:51 AM
Default Re: (chairwitharmrests)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chairwitharmrests &raquo;</TD></TR><TR><TD CLASS="quote">will, I be fine hardwireing the kit in the way it is? Or do I need one of those relay harness things?
Btw this is going in my 4runner not my civic, but the 4runner is also h4.</TD></TR></TABLE>
Buy a new HID kit, they are like 60 dollars on ebay, and no matter what unless you go with a real proven brand name, they are all relabled made in china boxes. I would buy a new kit altogether and junk that one, maybe save the bulbs.
Old Sep 2, 2008 | 07:55 PM
It is mcculloch, from what I have always thought and heard they make one of the best pnp kits. If i were to buy a kit of ebay for $60 id simply use the connectors on the kit I have. But honestly I cant picture myself ever paying money for any pnp kit........ Regardless I hardwired it and it works without any problems.
Old Sep 3, 2008 | 12:48 PM
1sick4g63's Avatar
My old plug was removed so i just soldered them into each other. No problems.
crist488
Sep 14, 2009 02:22 AM
datssoled
Mar 29, 2007 03:22 PM
