Lighting HID/Xenon kits, Retrofits and Associated Topics
Cursed headlight dilemma
Old Jul 30, 2008 | 07:46 AM
FhCRubarb's Avatar
Default Cursed headlight dilemma
So one of my headlight bulbs went out the other day and I lifted the hood to check for a loose connection etc. and upon shutting my hood the headlight that was out relit. The next day that same bulb went out but after trying many times to revive it by shutting the hood I gave up hope. However, the high beam does work on both lights. I would tend to think that the low beam filament went bad but I'm baffled as to why it cut back on when I shut the hood. Any input would help.
Old Jul 30, 2008 | 09:24 AM
striker_18's Avatar
it's not cursed. The problem lies with a rusted or socket which can be full of mud or oil. That will impede the current flow to go from the harness to the lightbulb itself. No current = no light. So, when you slammed the hood down, the connector shaked and probably fired a small current which made the bulb lit up. It happens all the time with older cars
Old Jul 30, 2008 | 07:58 PM
FhCRubarb's Avatar
Default Re: (striker_18)
Why would the high beam work then?
Old Jul 30, 2008 | 09:02 PM
striker_18's Avatar
Default Re: (FhCRubarb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FhCRubarb &raquo;</TD></TR><TR><TD CLASS="quote">Why would the high beam work then?</TD></TR></TABLE>
Because not everything will be corroded or be full of dirt. It happened to my eg. I would have to kick the headlight to get it to fire up LOL
Old Jul 31, 2008 | 08:41 AM
e46civic's Avatar
Did you try changing the bulb, its either that or what striker said. If the high beam works the fuse is good so that narrows it down to the other 2 choices.
jebjeb
Mar 14, 2007 05:21 PM
jdmazm
Sep 20, 2006 07:20 PM
OxYi
Nov 2, 2004 06:29 PM
bad93ex
Nov 23, 2002 05:55 AM
