Lighting HID/Xenon kits, Retrofits and Associated Topics
amber corner problem
Old Jul 21, 2008 | 06:17 PM
dvlsfan30's Avatar
Default amber corner problem
i have jdm amber corners and im having a problem
they turn on and work ok but when i put my blinker on it wont blink
any ideas on whats wrong or how to fix it?
Old Jul 22, 2008 | 12:54 AM
friesx100's Avatar
Default Re: amber corner problem (dvlsfan30)
Sounds like the bulb is a single intesity-- seeing as it works but wont flash.
Take the bulb out and check the #.
1156 is a single intesity with one contact; you'll probably need a 1157 dual intensity - two coils inside the bulb, and two contacts on the base.
Old Jul 22, 2008 | 05:29 AM
dvlsfan30's Avatar
ill try that today
thanks alot!
Old Jul 22, 2008 | 08:53 AM
dvlsfan30's Avatar
thanks alot man. it fixed the problem
it had the right bulb, it musta just been shot
Old Jul 22, 2008 | 10:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (dvlsfan30)
I'm sure the bright filament was just burned out. Was your turn signal flashing rapidly on that side when the bad bulb was in there?
Old Jul 22, 2008 | 12:30 PM
dvlsfan30's Avatar
yea the rear bulbs were on and blinked, the amber corner was on but wouldnt blink so i guess that was trhe problem.
jruiz094
Feb 3, 2013 09:15 PM
jasony0630
Feb 22, 2008 03:43 PM
Digiti123
Aug 2, 2007 06:20 AM
ThinHoanG
May 18, 2005 01:15 AM
AK94GSR
Mar 27, 2002 02:27 PM
