Lighting HID/Xenon kits, Retrofits and Associated Topics
Are all D2S bulbs the same?
Old Jul 7, 2008 | 07:08 AM
JDM-EJ698's Avatar
Default Are all D2S bulbs the same?
Im trying replaced my HID bulb which is a D2S.But I dont wanna pay $250 for the bulb on my mazda.I can get it at work for a lot cheaper.I work at land rover.My question is if I use a land rover bulb would it be a different color than the other side?It still is a D2S bulb.Or are they all them made by the same manufactor?
Old Jul 7, 2008 | 07:36 AM
e46civic's Avatar
Default Re: Are all D2S bulbs the same? (JDM-EJ698)
There are 3 major manufacturers, Phillips, Osram, and GE. They all will fit in your headlight, but they wont all have the same output. There will be some differances, mostly color, and a new bulb will not match your other headlight, especially if the bulb is a lot older. The only D2s projector Ive ever seen that only uses Phillips bulbs is the ZKW bixenon, Osrams wont fit.
Old Jul 8, 2008 | 06:51 AM
retrosolutions's Avatar
Default Re: Are all D2S bulbs the same? (e46civic)
what do you mean Osrams won't fit?
Old Jul 8, 2008 | 08:26 AM
e46civic's Avatar
Default Re: Are all D2S bulbs the same? (retrosolutions)
Put an osram and a phillips side by side and look at where the capsule goes into the base. Phillips has 4 prongs and the osram has a circle thing, the circle thing wont let the bulb sit flush in the projector, like I said the ZKW bixenon is the only one Ive ever seen like this.
Old Jul 8, 2008 | 05:33 PM
Right you are, I honestly never tried putting an Osram in a ZKW before.
Old Jul 9, 2008 | 09:48 AM
e46civic's Avatar
Kinda weird, huh? They must have a contract with Phillips or something.
Old Jul 10, 2008 | 10:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I highly suggest replacing HID bulbs in pairs, and only with brand new bulbs, to ensure that the color temperature and light output is the same on both sides.
You can get brand new OEM Philips 4300K bulbs on eBay for $80/pair, so I would start there.
Old Jul 10, 2008 | 02:00 PM
JDM-EJ698's Avatar
Default Re: Are all D2S bulbs the same? (PatrickGSR94)
I am able to get 2 D2S osram bulbs at work for about that amount.They should all be the same wattage right?
Old Jul 10, 2008 | 03:33 PM
All OEM D1S/R and D2S/R bulbs are 35w.
Our company is about the only source for true 55 watt bulbs these days, not even Philips produces their DL50s anymore. So not to worry, you would be hard pressed to buy the wrong thing.
Old Jul 10, 2008 | 05:07 PM
Community Builder
What? I thought the ballasts were what run at 35W or 55W. I could take a 55W ballasts and plug it into the D2S bulbs I've had in my car for 4 years.
Old Jul 11, 2008 | 07:07 AM
striker_18's Avatar
Default Re: (PatrickGSR94)
You can have a boosted ballast and run the same 35w bulb but then again that bulb will be boosted and run really hot since it wasn't designed for 55w to begin with.
Philips make DL50 D2S bulbs. They have over 5,000 lumens and are true 50w bulbs. they are used in airplanes and boats
Old Jul 12, 2008 | 01:16 PM
All OEM ballasts are 35w and so are the bulbs, but you can boost the 35w bulbs for a higher output at the expense of a shorter lifespan and higher temps. However, if true higher wattage bulbs are used the lifespan is the same as 35w, temps apparently are a little lower because of pressure in the cleft, and the output would be greater than a boosted 35w bulb.
Old Jul 12, 2008 | 03:53 PM
striker_18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 &raquo;</TD></TR><TR><TD CLASS="quote">I am able to get 2 D2S osram bulbs at work for about that amount.They should all be the same wattage right?</TD></TR></TABLE>
I can get a pair of philips 85122+ D2S bulbs for 15
Old Jul 12, 2008 | 05:58 PM
Default Re: Are all D2S bulbs the same? (striker_18)
used
Old Jul 12, 2008 | 11:13 PM
striker_18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by retrosolutions &raquo;</TD></TR><TR><TD CLASS="quote">used</TD></TR></TABLE>
New
Old Jul 13, 2008 | 05:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by striker_18 &raquo;</TD></TR><TR><TD CLASS="quote">
New </TD></TR></TABLE>
Really, because we can not even import Philips bulbs at that cost anymore.
Old Jul 13, 2008 | 07:26 AM
Community Builder
must be black market then
Old Jul 13, 2008 | 09:51 AM
striker_18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">must be black market then </TD></TR></TABLE>
Old Jul 14, 2008 | 04:46 AM
Community Builder
By black market I meant they were probably stolen from somewhere.
Buying stolen parts
Old Jul 14, 2008 | 06:51 AM
LOL, at best they are probably off the FX recall whcih would not be "new"
t3am 83rd
Lighting
Mar 19, 2009 08:13 AM
scanlous_styles
Lighting
Dec 19, 2007 11:44 AM
2000dollarzcbs
Sep 20, 2006 07:09 AM
Bbasso
Aug 19, 2004 10:17 PM
Hella Clean
Jul 15, 2002 06:28 AM
