Rust, what work, what doesn't?
Old Aug 26, 2012 | 08:49 AM
honda wrc's Avatar
Default Rust, what work, what doesn't?
Hey everybody,
Well my 02 SI is starting to get a little bubble of rust over the rear wheel wheel and was wondering what, if anything, has been done and tried that works. I've heard so much good and bad about POR15, rust bullet, etc etc that I am looking for firsthand info on what you might have tried and your results. I am sure that this has probably been covered many different times in the past but maybe somebody has some new info on a product or something.
Anyway, if anybody can help that would be awesome.
Thanks!
Old Aug 26, 2012 | 10:30 AM
AutoBodyByJake's Avatar
Default Re: Rust, what work, what doesn't?
Surface rust-sandblast out and fill. Rust all the way through- cut out and replace with metal.
Old Aug 26, 2012 | 07:50 PM
habanerored06si's Avatar
What bad have you heard about POR-15? lol.
The only issue about POR-15 is that the solution does not protect itself against UV rays, which therefore requires its other solution in combination with POR-15 that protects it against UV rays.
This.
However, if you're in Canada its not enough.
Surface rust
- Sandblast out/or sand out with 300 grit the loose rust/debris
- Apply POR-15
- Apply filler
- Prime
- PAint
Rust Holes (All sizes)
- cut/grind out
- weld in new metal
- Apply POR-15
- Prime
- Paint
Old Aug 27, 2012 | 05:21 AM
I've never use POR-15 in my shop. I was under the impression it was some type of undercoating to prevent rust? And Honda wrc, any time you are repairing rust and with a filler make sure it is a waterproof filler. Such as duraglass or all metal. These create stronger repairs that will not soak up water like regular plastic filler.
Old Aug 27, 2012 | 01:25 PM
honda wrc's Avatar
Ahh, sounds good and something I wouldn't have thought of ABBJ! As for the POR15, I have heard people comment on how it "just falls off" more than once, but I am supsect that it was probably poor prep work that led to the poor adhesion.
Do you guys think one of those abrasive sponge type wheels would be good? You know the ones that look like this http://cdn.instructables.com/FQ1/WTE...YXJ.MEDIUM.jpg
Old Aug 27, 2012 | 01:50 PM
That's the effect of UV ray's drying out the POR-15 leading to crumbling and breaking off.
Get a 2-2 1/2 inch wheel. There not sponge...there usually strands of steel/copper/wire on a wheel.
That plus an orbital sander and you'll be good.
Old Aug 27, 2012 | 02:12 PM
honda wrc's Avatar
Sounds good...I am gonna order up some POR-15. It seems the negatives I hear about it are always2nd or 3rd hand anyway!
Old Aug 30, 2012 | 07:29 AM
teg your it's Avatar
after cutting out and welding, what is does honda used to spray under the car? it's like a hard yello sponge like thing. then they coat with rubber.
EDIT
that yellow stuff is way better than rubberized spray. thats is what i am looking for. i have a hole near my foot rest and i am trying to patch that hole up with just sodering or some cold weld. then spray that yellow stuff.
markturbo
Honda Civic (2006 - 2015)
Jun 5, 2013 08:22 AM
xLaziestLa0b0ix
Honda Civic (2001 - 2005)
Oct 29, 2009 02:49 PM
Briman2021
12
Sep 21, 2003 06:28 AM
Quik89Si
Jan 12, 2003 01:22 PM
FourthGenHatch
10
Sep 13, 2002 09:03 AM
