Tackling Rust
Old Oct 27, 2012 | 04:56 PM
91EFH22's Avatar
Default Tackling Rust
Whats up everyone, the bed of my 87 Pup has been sitting in a car tent rusting away. Im using a grinder with a wire brush attachment to strip down what I can, what im having trouble with is the fact that the surface rust is coming off however it seems as though there is what appears to be leftover rust. What im wondering is can I use the wire wheel to get all of the rust off and then hit the bed up with Self Etching primer to take care of whatever is left after using a wire wheel? I plan on getting the bed LineX'd or Rhino lined so I dont believe this should be a problem.
Hopefully someone can chime in. Ive attached some pics....
Old Oct 28, 2012 | 01:03 AM
oversteer_ms's Avatar
Default Re: Tackling Rust
I would start with removing what you can with the wire wheel. But don't wear yourself out. At this point your not removing it but just slowing it down.
What I have found works the best for me is "naval jelly". Or another gel form of phosphoric acid. It works as a rust converter, spray it on scrub it and rinse it off. Sometimes several applications are necessary depending on how bad it is.
Once you feel as though you have it squared away I would use some self etching primer and a sealer as well. I usually use Transtar black. Two medium coats. Don't over reduce it or you'll run the sh** out of it.
Austin Johnson
Oversteer Motorsports
Old Oct 28, 2012 | 05:08 AM
91EFH22's Avatar
Thanks for the reply! I might go that route, I was wondering if just using a lets say 120 grit sanding disk to knock down everything to shiny metal would work and be a little bit faster?
What do you think Oversteer?
Old Oct 28, 2012 | 05:15 AM
Skatnshawn's Avatar
I would recommend usin 60 grit or rough steel wool to get deeper then pressure wash repeat til rust is real thin and take a good primer such as rust oleum and spray a couple good coats sand with higher grit paper and paint
Old Oct 28, 2012 | 09:50 AM
Whatever knocks it down quicker. Wire wheel, 60 grit, 40 grit. But the biggest step is going to be the phosphoric acid.
Chemicals are your best friend with an issue like this. Rust is like a weed and it will spread like wildfire without the right treatment.
And as far as the other guy posting, just scraping off a little rust and spraying some primer over it probably isn't the best idea if you are trying to have a rust free end product.
Old Oct 28, 2012 | 09:54 AM
coog's Avatar
id get some KRUST , gennolite on it and let it soak in first ,or even wd40 .etch primer should be best but make sure its not in primer long before you paint it . i made that mistake years ago and the primer allows moisture in/on
Old Oct 28, 2012 | 01:22 PM
91EFH22's Avatar
Again thanks for the replies. I think im going to grind down all of the rust and then Naval Jelly followed by epoxy primer.
Sound like a plan?
Old Oct 28, 2012 | 02:51 PM
92civiceg9gsr's Avatar
I would wire brush and sand off the worst of it then use Eastwood rust converter or fast etch before priming.
Old Oct 28, 2012 | 02:53 PM
91EFH22's Avatar
I have Eastwoods form of POR15.... That should do it if im not mistaken
Old Oct 28, 2012 | 06:56 PM
Hidenplanvew's Avatar
80 grit on a palm DA, dont put water on it it, your just going to give it chances to start in other loctions. Just use shop air and rag and wipe off while blowing air on it, use a wax and grease remover on it then epoxy surface sealer or etch sealer.. Not crap you can get from homedepot or walmart but real paint from PPG or Eastwood is ok, dont know about longevity of the eastwood paint. Follow the directions on the P sheet, You can find them on PPG's website under there Omni paint (omni is PPG's automotive line of paint)
Old Oct 29, 2012 | 09:46 AM
coog's Avatar
is it too bad to have sand blaster/ beed blasted ? if it still feels solid that would save you some wlbow work .
Old Oct 29, 2012 | 10:05 PM
KingDela's Avatar
helpfull thread!
Old Oct 30, 2012 | 06:15 AM
91EFH22's Avatar
I think im going to use a sand blaster on the joints I cannot get to and the wire wheel/DA to accomplish the rest followed by epoxy primer.
Old Nov 2, 2012 | 10:39 PM
XxDARKCYDExX's Avatar
If you plan on letting the bed sit for awhile, once you tackle the rust issue, it be best to etch prime over bare metal then epoxy seal it.
Old Nov 7, 2012 | 08:14 AM
james0429's Avatar
If you want to get rid of it completely your real choice is blast it , if you want to put it under the rug for a couple of years wire wheel , 36 grit and grind it out and just prime over it and seal the hell out of it .
heres a cheap project i was made to do for my sister , this was my first paint job i had to by my self it . verry veryy budgeted , grinded everything out as much as possible , primed it all , sealed it with a meddalion product and the paint was a single stage with 20 differnt scrap reds mixed together .
finish product looked pretty good ! hopefully it doesnt pop a couple years down the road.
Old Nov 7, 2012 | 01:22 PM
91EFH22's Avatar
Whats the difference between wire wheeling and grinding it off VS blasting it? I see why its best to blast out the seam areas but the open/flat ones should be ok using the latter no?
Old Nov 7, 2012 | 01:28 PM
aristides's Avatar
I would just get a DA with low grit or a grinder , just get it to shiny metal
And nice and smooth then primer
Old Nov 7, 2012 | 01:31 PM
aristides's Avatar
Oh and a wire disk on the hard to get spots
Old Nov 8, 2012 | 08:03 PM
j13's Avatar
j13
Have a problem sand blast it, have any holes patched up, then brush on a nice heavy coat of POR15. It cost a lot of money per pint, but it will protect it for ever
Old Nov 10, 2012 | 02:35 PM
ej1 rep's Avatar
Fastest and easiest way would be to blast it. personally I wouldnt even waste my time with a wire wheels.
Old Nov 12, 2012 | 04:45 PM
93nismo's Avatar
blasting it or having it acid dipped is the only real way to potentially get rid of all of it. there are places that will acid dip/blast and then dip it in a coating to cover every spot seam and crevice. that's the only way your going to maybe gaurentee no rust ever. if you cant or wont blast it. hit it with low grits and get what you can off. use a grinder in spots that are difficult. etch prime it and continue with normal refinishing steps.
crdcz03
Sep 10, 2020 09:23 PM
Hatorade
Apr 20, 2010 01:05 PM
cmross13
10
Feb 27, 2010 11:39 AM
misaelmelchor
Paint and Body
Nov 24, 2007 05:47 PM
