09 civic Si code scanner
Ok i have the VSA and /!\ light on, what scanner can i use so that it tells me the codes i need without having to go to the dealership, any info on this?
The car is a 2009 civic Si coupe
Re: 09 civic Si code scanner
I would first go to a tire store and ask them to check if all your tire sensors are working if the vsa does not read one of the sensors the light will go on.
Have you had any tire work recently where they could have destroyed one of your TPS sensors?
Nope no tire work, all ive done was take off the 2 front wheels tho... Idk if that couldve really messed it up but before i had taken em off the vsa light and /!\ wasnt on
I have only read a little on honda and scanners, from what I read it doesn't sound like any hand held unit like most consumer models will work without expensive honda software.
I doubt you broke anything just removing wheels if you messed with the sensor wires going to the wheels then you might have unplugged one.
I would start looking at fuses make sure there are none blown, use a test light some of those small fuses look good when they are not.
Make sure all the fuses will put the test light on on both poles, I have been fooled by that "looks good" just a few months ago.
You would most likely have to take it to a dealer. Handheld scanners usually only tell PGM-FI codes. I personally haven't seen a vsa light ON due to a dtc, only by manually turning it off. The other symbol u are seeing is just the low tire pressure light.
Not the fuses, my father is an electrician and he checked all the fuses twice with a test light and we didnt really mess with those sensors. today i plan on taking the car to the dealer and just get it checked, i will come back on soon and let you guys know what it was if i get the answer.
THANKS FOR THE HELP!!! I APPRECIATE IT GUYS
I was able to rectify my CEL (P0113), VSA, and ! problem by installing a new MAF sensor. I used a remanufactured sensor with no issue so far, about 500 miles.
Grumpycloud
03-01-2014 07:36 AM
