Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
coilover question
Old Nov 19, 2011 | 07:27 PM
stdefhatch's Avatar
Default coilover question
Posting for a friend, putting FF type 1 coilovers on an 06 si. Might be a stupid question question to you guys but do the adjustable perch for the springs go up top or on the bottom of the springs? This is for the rear only. Fronts are done and in place. Just never touched one of these civics before. Thanks in advance.
Old Nov 19, 2011 | 07:42 PM
stdefhatch's Avatar
Default Re: coilover question
And also, did everyone use the black rubber cone/spacer that sucks in at the top above the coilover?
Old Nov 21, 2011 | 08:38 AM
DFW's Avatar
DFW
Do you have a pic? If they are like the buddy club's then it's suppose to look like this
Old Nov 21, 2011 | 11:08 PM
bopbop93030's Avatar
it goes on top and the black rubber cone is not use.
Old Nov 22, 2011 | 03:43 PM
vladd's Avatar
I've never seen it not used with coilovers. You'd be putting metal against metal if you didn't use it.
Old Nov 22, 2011 | 10:04 PM
Because it's totally different design than the lowering springs and coilover setup.
from the picture above do u see the rubber cone on top of the spring perch?
Here's a member from 8thcivic that has the black version of the FF2. I have the red version
http://www.8thcivic.com/forums/suspe...over-woes.html
inside that black thing that has the spring perch is made of rubber so it is not metal to metal.
crxtuner0
Suspension & Brakes
Mar 9, 2009 04:01 PM
DJ_SaNdOz
Mar 26, 2003 12:42 PM
slowman
16
Mar 1, 2003 04:19 PM
Finest
Feb 3, 2002 06:45 AM
