Annoying rubbery type squeak
Hi guys,
Can anybody help, I have a 2007 CTR, and recently an annoying rubbery type squeak has developed around the near side bottom corner of the windscreen, and it's driving 🚘 me around the bend. (no pun intended) Has anybody had a similar problem, or know of a way to solve the problem. Any help would be appreciated. Cheers
Re: Annoying rubbery type squeak
Google for "Honda ATS100303". Once you remove the cowl do what the Bulletin says and then test drive it before putting everything back together. If you still hear the noise you might want to lubricate between the metal and windshield (from the outside) with some WD40 and test drive again. If the noise is gone, you should think about a more permanent solution like putting some antisqueak tape or anything more durable.
Regards
Regards
Cheers bud, I haven't had the car long,so I want to take the scuttle of in the next couple of weeks to change the plugs and paint the rocker cover, so, I will kill three birds with one stone. Thanks for the tip off.
HoUTX98GSR
18
05-24-2010 11:07 AM
