transmission sounds and jerking
I got a 2013 civic SI coupe and for a while... I thought it was the smoothest manual transmission I have ever driven. Maybe about a couple of months ago, I started hearing the change of gears every time I shifted. It use to be fairly quite but now it seems it is getting louder and louder to the point that even with the radio on, I can hear the sound every time I shift (usually happens in the lower gears. 1,2,3)
That is not the biggest issue though. The shifting from 1 to 2 has some major jerking. The moment that I release the clutch and step on the gas, no matter how subtle I try to be in the transition, it feels as though some one rear ended me. In addition, every time I drive in second gear (and it only happens in second and first gear) and then take my foot off the gas the same level of jerking occurs...maybe even a bit more.
This is not how it use to drive. Has anybody experienced this or has any suggestions as to what it could be? Any information is helpful!
Re: transmission sounds and jerking
Change your transmission oil to a synthetic like Amsoil. It smooths out the shift somewhat and kills the shift noise. As for the bucking, are you dumping the clutch? I can't think of a way to dampen that symptom.
cag022
Transmission & Drivetrain
09-07-2015 12:42 AM
1Cloudwalker1
07-17-2005 04:35 PM
