cage help
Old May 18, 2005 | 09:29 PM
CaptainMorgan's Avatar
Default cage help
I just got my s&w roll cage. The way they have it set up is the rear bars, sits right before the shock. That is a really bad spot. Anyone have pics or advise.
Old May 19, 2005 | 02:39 PM
Default Re: cage help (CaptainMorgan)
bump
Old May 19, 2005 | 04:12 PM
hondaguyef's Avatar
I pm'd someone for you. Hopefully he'll chime in and answer your question becasue I am getting an S&W cage as well and would like to know.
Phil
Old May 19, 2005 | 05:19 PM
93LSivic's Avatar
Default Re: cage help (hondaguyef)
That would be me that Phil PM'd
I have them in my EG. They goto the floor beside the rear shock towers. The seats do still fold up and just enough so that the bar touches the tops of them. I do plan on modifying the bars so that there is a bar that goes from tower to tower sideways and then welding the rear bars to that support, like most of the other cages you will see.
Also with this setup then fitment is probably a 7 out of 10. You will need to grind the ends for good fitment if you get a mild steel cage, and grind a bit more precisely if you get the chromoly (TIG welding) since you cant really fill gaps well.
Heres a thread I made after I put them in. Good luck with your project
https://honda-tech.com/zerothread?id=493472
Old May 19, 2005 | 05:26 PM
hondaguyef's Avatar
Default Re: cage help (93LSivic)
Thanks Dan
Old May 19, 2005 | 05:31 PM
tommyten's Avatar
whats the advantage to having the bar across the towers & welding both rear bars to them?
Old May 19, 2005 | 05:38 PM
16vt's Avatar
If it's like mine,those bars are long and have some flex,the cross tube takes that flex out.
Old May 19, 2005 | 06:38 PM
93LSivic's Avatar
Default Re: cage help (Tommy Ten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy Ten &raquo;</TD></TR><TR><TD CLASS="quote">whats the advantage to having the bar across the towers & welding both rear bars to them?</TD></TR></TABLE>
Tommy, whats up my brother
AFIAK there isnt much structural support on the back floor of the car. Im not a chassis guy and maybe they can chime in. But if you look at any car that has had a cage installed by a reputable chassis shop you will usually see this.
I would think that you would want an X brace coming from the hoop and going to the tower support for ultimate support. I wish I would have spent more money on my cage but at the time I was on a budget.....hell, I still am.
Old May 20, 2005 | 07:58 AM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
AFIAK there isnt much structural support on the back floor of the car. Im not a chassis guy and maybe they can chime in. But if you look at any car that has had a cage installed by a reputable chassis shop you will usually see this.</TD></TR></TABLE>
That is it Dan. Most of the floor is just thin metal. The shock towers are the strongest part of the car structuraly. The crossbar to the shock towers add support for the rollbar but also stiffness side to side. Tony did it this way on Art's car.
Old May 20, 2005 | 10:03 PM
bigTom's Avatar
Default Re: cage help (DIRep972)
actually under some of the sheetmetal is the unibody frame which is also a strong sound place to mount the bars 2... i go back and forth between mounting the bars to the rear of the car above the frame or to the shock towers... or ill do both
Old May 21, 2005 | 05:55 PM
93LSivic's Avatar
Default Re: cage help (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">actually under some of the sheetmetal is the unibody frame which is also a strong sound place to mount the bars 2... i go back and forth between mounting the bars to the rear of the car above the frame or to the shock towers... or ill do both</TD></TR></TABLE>
This is true. I placed my rear bars over the "frame" on the floor, pretty much the same place that the rear steel bumper bolts to.
061000rr
Welding / Fabrication
25
Oct 4, 2010 06:51 PM
96 GSR-T
14
Mar 24, 2008 09:20 AM
JDMkidMARC
Apr 14, 2007 05:59 PM
artifex
Jan 7, 2002 08:37 AM
