Engine diapers
Old May 4, 2005 | 04:13 PM
SFWD tC's Avatar
Default Engine diapers
Is anyone using an engine diaper system? If so which one and how does it fit. Is it easy to put on and any pictures of one on a car. Or is everyone using a pan under the motor.
Old May 4, 2005 | 04:55 PM
lugnuts's Avatar
Default Re: Engine diapers (SuperTwinz)
bump because there was too many oil downs the other day at e-town!
Old May 4, 2005 | 05:11 PM
h22 civic's Avatar
Default Re: Engine diapers (lugnuts)
oil spilage and brain dead people that i guess cant see smoke burlowing out their car and insist on draging it down the track caused lots of down time this weekend as if things with the weather where not bad enogh these diapers should be mandatory
Old May 4, 2005 | 05:32 PM
SFWD tC's Avatar
Default Re: Engine diapers (h22 civic)
last I knew they were mandatory. That's why I thought some people would know some info on then because they should be using one. If not how are they passing tech at the events.(NHRA OR NDRA)
Old May 4, 2005 | 05:38 PM
MarkyMarkPRWD's Avatar
I was told by NHRA that the oil down time on Sunday (Etown) was <U>3 HOURS AND 15 MINUTES!!! </U>
Obviously, no one is using their blankets. Possibly they just don't work. This affects all of us. PLEASE use your diapers.
Also, please pull over to the side of the track instead of dragging your oil all they way to the last turnout. Synthetic oil is the worst. They actually have to use wire brushes to get it off the track.
This sucks for RACERS and mostly the FANS.
Old May 4, 2005 | 05:56 PM
Quik Chris's Avatar
Default Re: (AEMmark)
If you knock a rod through the front of your block, you're going to oil the track regardless if you have a daiper or not, but in some instances, they can eliminate or reduce the amount of oil that gets on the racing surface.
Anyway...
http://www.jegs.com/cgi-bin/nc...r=361
There's no one way to install them, basically just get the straps to a certain length, and find attachment points around the motor.
Old May 4, 2005 | 07:21 PM
NFJohn's Avatar
Default Re: (Quik Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris &raquo;</TD></TR><TR><TD CLASS="quote">If you knock a rod through the front of your block, you're going to oil the track regardless if you have a daiper or not, but in some instances, they can eliminate or reduce the amount of oil that gets on the racing surface.
Anyway...
There's no one way to install them, basically just get the straps to a certain length, and find attachment points around the motor. </TD></TR></TABLE> If the diaper is made properly, it will contain most if not all of the oil. Go look at a fuel car motor. You can barely see the thing, because the diaper almost totally incapsulates it. Look at the bottom of my sig and see the link for Taylor Motorsports. Most every fuel car, and funny car runs his diaper. If someone could get him a "COMPLETE" motor, he will make it right with mounts and all. His name is Dennis. Give him a call.
Old May 4, 2005 | 07:49 PM
OaksRacing's Avatar
Default Re: (NFJohn)
We are running with a Deist engine blanket. Very happy with it.
Old May 4, 2005 | 11:05 PM
Quik Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NFJohn &raquo;</TD></TR><TR><TD CLASS="quote"> If the diaper is made properly, it will contain most if not all of the oil. Go look at a fuel car motor. You can barely see the thing, because the diaper almost totally incapsulates it. Look at the bottom of my sig and see the link for Taylor Motorsports. Most every fuel car, and funny car runs his diaper. If someone could get him a "COMPLETE" motor, he will make it right with mounts and all. His name is Dennis. Give him a call.
Though I'm not completely agreeing that the diaper is the ultimate solution to the problem this past weekend, I think it would have helped a lot. The problem that the Hondas have with daipers is the possibility of it catching on fire or melting on the downpipe/header. I know many people who still fee uncomfortable using them because of this. The header/downpipe also causes poor diaper fitment-- whereas all the V8's you're talking clearly have never run into this problem.
On paper, it's a great idea, but I'd much rather have a race delay than someone's car catching on fire and being injured or worse because of a car fire dealing with a diaper.
I'm neutral on the issue, just trying to show that the bottom line is the diaper is not the ultimate solution to the problem.
Old May 5, 2005 | 01:27 AM
civic disobedience's Avatar
It seems nobody is making any "custom fit" or "model specific" parts. Seems like 1 more among the myriad of parts that need to be fabricated for a serious race car.
Old May 5, 2005 | 05:10 AM
tony1's Avatar
The blankets won't catch on fire, they will melt, but won't catch fire. We melted Bryan's on the anti lag. The best way to do it is to make an aluminum belly pan that goes from front to back of the engine bay, and from side to side as wide as you can. Then you make a 1" lip all the way around. Kenny, Bryan, and Chuck all have a setup like this and it's way more efficient at catching oil and water than the blanket.
Old May 5, 2005 | 05:44 AM
lugnuts's Avatar
Default Re: (tony1)
Plus they act as an aerodynamic adder.... is there a spec on the belly pan thickness when using aluminum and/or steel?
Old May 5, 2005 | 05:57 AM
tony1's Avatar
Default Re: (lugnuts)
There's no spec, but i'd do at least .032 aluminum.
Old May 5, 2005 | 07:46 AM
velocitytrends's Avatar
Some pics would be nice of the this engine diaper.
Old May 5, 2005 | 08:13 AM
PNG's Avatar
PNG
Default Re: (velocitytrends)
[ruthless pimping]
Find the June issue of OverRev at your favorite tuner shop or at a NDRA drag race, and go to page 56 for an article on oil containment that has some more info on diapers and catch pans.
[/ruthless pimping]
Old May 5, 2005 | 08:57 AM
Quik Chris's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">The blankets won't catch on fire, they will melt, but won't catch fire. We melted Bryan's on the anti lag. The best way to do it is to make an aluminum belly pan that goes from front to back of the engine bay, and from side to side as wide as you can. Then you make a 1" lip all the way around. Kenny, Bryan, and Chuck all have a setup like this and it's way more efficient at catching oil and water than the blanket.</TD></TR></TABLE>
Yeah... I supose they wouldn't actually catch on fire unless a flame was held to them, but at the same time, it's something we always kind of groaned about using. The front belly pan seems like a much better idea--I never thought about it becuase of what they always say at tech-- "where's your diaper?" Time to get the air nibbler out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNG &raquo;</TD></TR><TR><TD CLASS="quote">
Find the June issue of OverRev at your favorite tuner shop or at a NDRA drag race, and go to page 56 for an article on oil containment that has some more info on diapers and catch pans.</TD></TR></TABLE>
Thanks for the info... we just got the new issue yesterday. Did you see that article about the K20A2 that was stock with Hondata and TWM ITB's? 243 @ the wheels!
velocitytrends: Here's a pic of a diaper-- it's the only one of the HCi that I could find, but there were a couple others if you do a google image search for "engine diaper"
Old May 5, 2005 | 03:01 PM
CHEETAH's Avatar
did anyone contact Bob Stroud @ 800-554-4648 ? i got mine from him. he has a b-series kit with good slack.
greg
Old May 5, 2005 | 03:15 PM
Bottle's Avatar
There are many companies that will custom make this product.
We had a Taylor make us ours for the PRO cars and the street cars.
There is also
Deist
RCI
or Stroud.
Old May 5, 2005 | 03:18 PM
Bottle's Avatar
these companies will make anything to your drawing. So you can make it so it will clear your headers and what not for the FWD cars.
Old May 5, 2005 | 04:09 PM
SFWD tC's Avatar
Default Re: (CHEETAH)
Ha Cheetah can you post some pictures of your blanket?
Old May 5, 2005 | 04:24 PM
Default Re: (ChopTopSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChopTopSi &raquo;</TD></TR><TR><TD CLASS="quote">Ha Cheetah can you post some pictures of your blanket?</TD></TR></TABLE>
What did it cost you if you don't mind my asking??
Old May 6, 2005 | 05:06 AM
Thanks for the pic!
Old May 6, 2005 | 07:08 AM
fast is fun's Avatar
RCI<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris &raquo;</TD></TR><TR><TD CLASS="quote">
Kevin
Nov 9, 2010 06:44 PM
jalow69
Oct 15, 2005 07:19 PM
.David
Jan 20, 2004 08:07 PM
Ex-ITR5874
Aug 21, 2003 04:14 PM
davidnyc
Apr 24, 2002 11:59 AM
