15.5 eg/ls?
Old May 6, 2005 | 10:34 PM
93cicvicls's Avatar
Default 15.5 eg/ls?
new here but was wonder what i should be running?I have a eg full interior,94ls swap and nothing much more.i ran on 13s on front only thing i had atm and 17s on back (cracked a front rim on pot hole).o2 sensor is bad and clutch is gone atm cant launtch at all really,but heres what my slip reads
60...2.589
330...6.821
1/8...10.379
mph...70.03
1000...13.399
1/4...15.588
mph...88.73
car is in the works for my 14b set up soon as i get my wastegate and oilkit in,intercooler is already mounted have a few pics of the car and my set up if any want to see
thanks for the look
Modified by 93cicvicls at 8:30 AM 5/7/2005
Modified by 93cicvicls at 8:31 AM 5/7/2005
Old May 6, 2005 | 10:38 PM
hatch34's Avatar
Default Re: 15.5 eg/ls? (93cicvicls)
that doesnt seem all that bad if you have all that **** wrong with it and you cant drive. my buddy ran 15 flat with his ls swap with a fucked up clutch. do you have ls tranny or a diff one
Old May 7, 2005 | 04:31 AM
Magick211's Avatar
Default Re: 15.5 eg/ls? (hatch34)
Those times are more than good with a bad clutch. I would say
Old May 7, 2005 | 07:21 AM
93cicvicls's Avatar
car has the ls tranny,stock clutch,the motor started as a block so the maint. was done and the clutch had atleast 60% off life left so i just left it in and put the $ into new gaskets/tbelt/and a few other things.i use a apexi ws2 exaust and had a bad vibration so i think thats what blew the o2 sensor.on the launch i have to almost roll off the line thats why my 60 sucked....but the car still looses traction in 3rd?so all in all if i dont launch above 3krpm car holds gd anything above the clutch will just slip right through 4th.does the car have a chance at running 14s?my bud was running a b16sedan at 7 psi and was getting in the 12s.i know the car will go 12s with the 14b but figure if i can get it running in the high14s na that boosted 12s should be np
Old May 7, 2005 | 10:51 AM
hatch34's Avatar
if youcan hook up then you should hit a 14 not a low 14 but it should be in the 14's
Old May 8, 2005 | 03:58 PM
roydogg's Avatar
bring that 60' time down some and full throttle shift through all gears. Then you'll be in the mid to low 14's. And get some azenis tires
Old May 9, 2005 | 08:46 AM
tony n.'s Avatar
Default Re: 15.5 eg/ls? (roydogg)
my boys hatch with a ls with i/e but stock hearders ran a 15.4 on 17's
Old May 9, 2005 | 03:46 PM
quicksol95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch34 &raquo;</TD></TR><TR><TD CLASS="quote">my buddy ran 15 flat with his ls swap with a fucked up clutch.
Originally Posted by boosted2cam
my boys hatch with a ls with i/e but stock hearders ran a 15.4 on 17's</TD></TR></TABLE>
my buddy's dog great aunt sal had a ls eg swapped and went 14.8s
O16581724 5 2 5
Mar 16, 2007 10:42 AM
ProjectLsEg-6
28
Feb 24, 2004 07:08 PM
integraguy17
Feb 3, 2004 07:31 PM
