View Full Version : Honda Fit
Pages :
1]
11
12
- Honda Fit 2005 Swap K20a3
- 2nd Gen Fit Throttle Pedal/DBW Connector Pinout
- Can 2015 Fit Driver Seat Replace a 2009 Fit ?
- Honda Jazz, 2004 model, misterious problem
- P0420
- MY CAR IS MISFIRING
- Transmission fluid change - afraid of a full change
- B Series Water Pump
- 2020 Fit- what do I need to know?
- AC compressor connector
- 2007 Fit EPS compatability
- Car randomly loses acceleration
- ABS Code 14-01
- Location of Fuel Pump Relay - Honda Jazz 2021?
- Honda fit 2013 cant go beyond 4000rpm
- 2013 honda fit gk3 engine problem
- Maintenance minder code A 1 4
- ‘08 manual tranny issues
- need help identifying this part of the engine
- Brake pedal hard, please help!
- car won't start, new batter
- 2007 honda fit left blinker issue.
- Battery in the key died. Replaced it and now it is no longer recognised by the car
- A Sob Story: Replacing Oil Pan in 3rd-Gen Honda Fit LX
- Honda Fit Hybrid System Inspection Messages
- Use OEM microphone on aftermarket radio
- No ground at fuel pump relay
- 2010 Fit massive oil leak
- 2008 Honda Fit Misfiring
- main relay location 2003 jazz
- Engine swap
- 2019 Fit with 27,000 miles
- Honda Jazz e:HEV UK - Need CAN Bus Trace or Individual Messages & Dash Pinouts
- Battery Life
- 2008 Fit: Recommendations for upgrading rear shocks and springs?
- 11 starter is OK for 08 Fit, except...
- 2016 fit bad start button removal
- 2022 FIT radio
- Chassis compability Jazz 2011 hybrid
- 08 fit MT year options / replacement
- 2023 Honda Jazz
- Clutch work on FIT 2017
- New Head unit, retain right turn camera?
- jazz 1.2 idsi 2007 map ntc sensor/ecu problem
- 2013 Fit belt window weather molding
- 2019 Honda Fit Permanent DTC won't clear
- u3000-49 ACC Unit Internal electronic failure
- Can the Fit tow a trailer?
- Window molding
- Ken Block has passed on
- Mr
- FIT occasionally rattles at start-up
- P0715 + Flashing D + Engine Light + Shudder in low RPM (up to 2K)
- Takes longer for RPMs to come down after cold start
- Considering a lightened flywheel
- 08 Fit quarter panel
- JAZZ - Thread Protector - 071AF-S3VA000
- Rear Disc Integrated Parking Brake - How does it work
- anyone know what this hose is?
- 2009 Honda Fit EGR Valve
- Disabling the eps electric power steering to prevent pulling left?
- Intermittent Crank no-start | 2013 Honda Fit
- P0420 Code on 2007 Honda Fit
- Honda Jazz 2004 Idle problem and Check Light
- Rear camber specs for each wheel or summary?
- 2018 Fit EX alarm/electrical gremlin
- Splash guard/Skid
- Previous owner woes
- Brake pedal getting stuck with noises
- 2008 Fit Sport - list of issues, need help with diagnosis.
- Honda Fit 2005 Water Leakage
- 2009 suspension question
- 2007 HONDA FIT SPORT P0302 MISFIRE #2 , CRANK NO START
- AC Pully not lining up after replacement on 2010 Fit
- Radio Serial Number with rearview camera
- Rear main seal leak / automatic transmission removal on '09 Fit Sport AT
- Splash guard replacement
- Advice
- First mod I should do
- Jazz 2010 - A/C clutch/pulley/compressor
- Brake Booster delete
- Not locking into park sometimes
- Excessive water from Honda Fit exhaust?
- Jump Start 2019
- GK5 Fuel Economy
- rear tire cupping need new shocks?
- Fuel Pump Relay Location
- How to use the "Exterior mirror tilt for reverse door mirrors"?
- 2009 Fit with PO171 code
- Poor Gas Milage and Oil Life
- Stereo Unit Options
- Acons in the roof, 2018 Honda Fit
- Power steering went out
- Water leak when parking outside Fit 2017
- Fogging windows
- 2007 Honda Fit - Remote starter
- WeatherTech floor lines (mats)
- Question for GK5 MT owners - "clunking" sound when depressing clutch
- 2007 Honda Fit/Jazz crank sensor repeatedly failing
- 2018 Fit shudder under power....?
- fog lights out
- Does the 2020 model have automatic breaking while reversing?
- Replacing Clutch Slave Cylinder
- 2017 HONDA FIT CLUTCH PEDAL SPRING FELL OUT
- Engine light on after hitting undercarriage with a rock.
- 2008 Fit fog light kit
- Need help with 2016 Honda Fit keyless entry etc. problems
- Engine help
- Ecm code 2009 fit
- Honda Fit 2008 Keyless Entry Module
- MPG difference of Base and Sport
- Need Accessory power to stay on
- 2007 Honda fit alternator/electrical issue
- Engine compartment plastic part location Jazz 2005
- 2008 Fit battery not charging
- 2007 honda fit
- Spider Infestation in door panels
- Alarm going off randomly 2007 Honda Fit LX
- Honda Fit
- Axle Recall done by dealer now ABS BRAKE lights on
- Iphone holder for Honda Fit
- A Complete K-Swap Guide Honda Fit/ CR-Z
- ECU Diagram
- Gary
- 2013 Fit MT Shudders in 1st Gear
- Exhaust for 2018 honda fit sport
- OBD2 Scan Tool for Honda Fit 2011
- Coolant level
- Issue with 2014 Honda fit Hybrid start up
- 2008 HONDA FIT REAR ALIGNMENT SHIMS
- Tool Sizes Required
- 2012 Honda Fit cranks only
- Front noise when it rains
- 2018 Honda Fit- turbo install
- Jazz/Fit VSS sensor
- 2015 Fit CVT Strainer Change
- What happens if you are driving over 60pmh and you accidentally put your car in neutr
- swapping a 2006 honda fit A/T ecu to a M/T vehicle
- 2015 Fit drivers side water leak
- Honda fit 2005 Gd1 P1887 error code
- Difference Between Honda Fit and Jazz
- 2004 Honda fit cigarette lighter problem
- $200 to change fan knob light
- Fit Brake Shoes
- Fit Sport Tires
- Alignment issues 08 honda fit need help
- Power Window Switch Assembly
- 2008 Honda Fit Sport Power Window problem
- HR-V brakes on a 2009 fit
- Door rattle solved...I think
- Rubber Ring for Spark Plug chewed up
- Rear window defogger not working please help
- Fit 2019 Hesitation accelerating
- Replacement for Driver's Seat
- 2015 Honda Fit ex 6mt passenger window with camera replace
- Start Stop Button Replacement Problem
- 2017 Fit door unlock issue
- 2014 Honda Fit Makes Noise on Start-Up
- 2007 Sport Loud Exhaust Issue
- Strange coasting behavior in 2016 Honda Fit
- Brake wear indicator
- Steering column stalks
- Good purchase?
- My tpsm sensor broke.
- Honda Fit tires
- Rear window cranck/handle, how to remove
- Wiper relay location 2009 Honda fit 2and gen
- Air conditioning 2008 Honda Fit base
- HONDA JAZZ CODE 22 - Excessive change of the vehicle speed Sensor signal
- 2015 Honda Fit misfiring
- Bluetooth Connectivity Issues - incoming call
- Locking gas cap for 2013 Fit?
- 2nd gen automatic vs manual. general opinions
- Can't find TPMS button on '15 Fit
- Crank no start after head gasket repair
- How to Fix Your Honda Fit's Ticking Valves
- Clunking noise coming from front driver's side
- 2008 Fit L15A1
- Cruise control main switch fix
- Radio Issue
- larger tires on 2008 Fit
- Fog lights
- Shifting to Neutral (auto trans)
- Towing 2019 automatic Fit
- Fuel injectors no pulse
- First 2020 Fits
- Cooking with FIT
- 2020 Model Year Fit
- Power sockets not working
- Abnormal noise
- GK5 LED Headlights (?)
- Is There a Taller 5th Gear for the 2009-2012 Fit?
- Towing the Fit
- Honda Vezel 2016
- 2013 Car having trouble starting in cold weather
- Dual clutch or CVT
- 2010 Honda Fit Electrical Issue with Passenger Headlight/Running Light/Blinkers
- Lizard died in front windshield defroster vent. Help please :(
- Fit GP5 Dual Clutch
- Honad Fit clutch hard on the knees?
- 3rd gen short shifter?
- Unsure about knocking sound front left tire
- 2019 Honda Fit TPMS Light Reset
- Fit 2009 failing to start
- scanner wont connect to ecu after rainy day and key started flashing too
- SRS on at hiway speed
- 2007 fit loose key in ignition
- '13 Fit fuel relay problem
- 2007 Honda Fit Sport Head Gasket Issue?
- Honda Fit Jerk -CKP Sensor P0339
- 08 Fit Sport Flickering Instrument Cluster
- Adding cruise
- Looking for 2017+ Fit, sway development
- 2000 Honda Logo SRS components
- Heater / AC Blower Question
- 2011 fit throttle control relay location
- 2010 Fit Sport horn, brake lights and cruise problem
- Replacement Maser Cylinders for Honda Fit
- Navi ststem upgrade
- Advice needed..Rear wheel liner removal
- Water in spare tire compartment
- 08 Fit Sport A/C doesn’t turn on
- 2009 Honda Fit - O2 sensor Bank 1 Sensor2
- DTC Trouble Code Meaning
- Normal discontinuity at seam of dash moulding?
- Weird noise on decelerating when stopped
- Considering getting a Fit but i have a few questions.
- 2013 Fit - Hard to stop
- What onstitutes gentle RPMs in the winter?
- Poor miles per gallon
- Full Size Spare Wheel - Will it Fit?
- Bulb replacement
- Depleted Honda Fit battery -- how long to recharge, how to re-enable radio?
- 2017 Fit Shaking on speed 40+mph
- Honda Jazz GK 2017 5" Radio backup camera install
- How to determine if mirrors on Honda Fit are being heated?
- 09 Fit Transmission Fluid low and foaming
- 2018 Honda Fit Tire Pressure Sensor issue
- Stumped with electrical issues
- Wheel alignment question
- Tries to shift when at a stop.
- Hand brake freezes and defroster seems nonfunctional after flood remediation
- Honda Jazz ABS/Bearing Problems
- Brake line freezes during first winter snow after flooding
- can't get into car
- my fit doesnt drive above 20km/h
- Ge8 front lower control arms question
- Where can I locate the front impact sensor as well as the enviroment temp. sensor?
- Troubleshooting Code P0302 - Any Spark Plug How-tos
- 2015 Honda fit is slow as hell
