The Honda OEM oil filter cap wrench size is listed as 65mm. Be aware that aftermarket oil filters do vary slightly in size.
Spark plug socket is 5/8". Specified Torque is 18 N-m (1.8 kgf-m, 13 lbf-ft). You can use a little anti-seize; however, some brands do not recommend them on new plugs. https://ngksparkplugs.com/en/resourc...ut-spark-plugs
Lug nut socket size is 19mm.
Honda recommends their Honda manual transmission fluid. Fluid change is 1.6 U.S. quart or 1.5 litre.
