Maintenance minder code A 1 4
Maintenance minder is giving me A 1 4. That suggests that spark plugs have to be changed but they were replaced only 2 years ago. I expected them to last much longer.
(1) Any suggestions?
(2) Following spark plug replacement do I need to reset the minder?
Thanks.
Thanks.
You will reset it in the vehicle settings like you would for the oil change. The car does not know when you replace the spark plugs, so unless you have driven a ton since the plugs were replaced, they are likely good.
volkracing99
Dec 2, 2002 09:49 PM
AutoboTxEK
Apr 3, 2002 09:49 AM
