Pulled dent problem. Help
Old May 30, 2009 | 10:34 PM
Hatchback of Notre Dame's Avatar
Default Pulled dent problem. Help
so a branch fell down and hit my EM1 in the rear right quater panel and dented it, right above the seem.... it was a pretty nice sized dent probably about the circumference of 2-3 inches..... so i had this dent puller thing that i never used (with the glue / suction cup things that you twist out) and it pulled the dent out after a few tries.... but i realized that now it bumps outward instead of denting inward. and it still looks shitty..... any recomendations on how to fix it???? idk if i should try tapping it back in lightly, or if i should leave it alone and see how much a body shop repair would cost...any ideas? i dont have any pics right now but my explanation is pretty self explanitory
Old May 30, 2009 | 11:09 PM
gorillafart's Avatar
Default Re: Pulled dent problem. Help
i say you sue the city. u probably wont get anything but its worth a shot
Old May 31, 2009 | 12:06 AM
Eyger's Avatar
Those dent puller things are a scam, then never work. If you can't get to the back side to hammer it out, then you need to weld on metal studs and use the slide hammer to back em out. At this point, I would leave it and take it to the shop. (assuming that you don't want to do it yourself. Although you could.) If you tap it back in, that'll make it worse.
rak511
Apr 11, 2013 11:36 AM
socals2k
Honda S2000
Feb 6, 2006 09:09 PM
mdarnell
Apr 18, 2005 04:47 AM
dumbchild
Jan 8, 2004 05:32 PM
Seann
Apr 15, 2003 09:14 PM
