On going Project
Well i'm going to start working on my car, which is also my daily driver,
since this might take a little time, i'll be working panel by panel
I'll be using PPg products, and Evercoat Extreme
now my question is after the bodywork what product can i use to protect the panel from Sun, Rain, ect... when i use the car?
my plan was to
sand to metal, epoxy prime, filler, then What??? 2kprimer or epoxy primer to protect from environment?
Thanks for your help,
my plan was to
you wanna put the filler on the metal then prime that spot...you want the best adhesion for the filler. 2K is what you put down over all the old paint and primer spots. I my self on body areas that i worked i put down DPLF.
will i be`able to use my car with the DPLF on it?
Lets say after puting that Epoxy primer, it might take me a month or two before putting the basecoat?
will that primer be able to withstand rain, sunligh, ect for that time?
yea the DPLF will. i had it on my car for 2 months when i was doing work then having to drive it around
also it come is many color black white red green gray
when i based my car i sanded the entire car with 320 to make sure everything was scuffed. then i washed it DX330'd the car put down 2K sealer then based cleared
o yea i forgot when you scuff your car DO AROUND the windows many many times. a friend of mine just did his car and we were tapein it off and we pulled the paint right off the car...oooops now he has to blend the sail panel
fragmare
Paint and Body
Oct 28, 2012 08:54 PM
jerebear
Mar 26, 2006 07:58 AM
