Pre Project checkup Help
Old May 19, 2009 | 09:56 AM
zuptidi's Avatar
Default Pre Project checkup Help
Sup guys I’m going to start working on my prelude 2000.
I recently bought this car and the body was banged up and bicolor. Lol
I want to repaint it the stock color
Now It’s summer time and I have time to work on it.
The only major thing is that there’s a little surface rust in a hit area on the rear panel, since the paint chipped off a bit and the metal was exposed.
I just want to be 100% sure as to the steps I’ll take
first I’m going to sand the surface rust area down and use Rust converter or Rust Bullet
Then use a epoxy primer over the rusted are then filler (Evercoat Extreme) and do bodywork on other areas
Wetsand the whole car and use 2k Epoxy Primer ( Any Recommendations?)
Then use a primer( Any Recommendations)
Now my question is that this car is my daily driver and is it ok to use it during this process?
Be aware that I live in Miami and the sun hits hard and its beginning to rain.
It could take me a bit of time to get the Base coat on there.
Thank A lot guys
Ill due another thread when I start up the work
Old May 19, 2009 | 09:07 PM
Eyger's Avatar
Default Re: Pre Project checkup Help
The epoxy primer will create a good barrier between the metal and the environment. So you'll be fine driving around with it. I have been driving around with mine primered up like that no problem. Use whatever primer that the company makes to which you are buying paint. If you buy PPG paint, use PPG primer, If you use Dupont paint, get dupont primer.
zuptidi
Paint and Body
May 24, 2009 01:57 PM
civic_90
May 3, 2009 10:30 AM
eg6itr069
Paint and Body
Mar 26, 2009 11:39 AM
SlammedEG6
Paint and Body
18
Feb 24, 2009 02:49 PM
MI4$DC5
Feb 26, 2005 07:15 AM
