Fast, Medium, or slow??
Old Jun 13, 2009 | 12:41 PM
Luke G.'s Avatar
Default Fast, Medium, or slow??
Im ready to order the hot rod flatz paint and i dont know which i need the fast, medium, or slow kit? Im in PA and the temp should be about 70 when i spray it.
Old Jun 13, 2009 | 12:58 PM
Eyger's Avatar
Default Re: Fast, Medium, or slow??
That's interesting, I was using the search feature and your post just appeared, when I hit the back button. Probably cuz you just created it. Anywho. You're going to want to use the medium reduced/reducer for temperatures around 70 degrees. On each of the different kinds, on the tech sheet it'll tell you which temperature frame to use which product.
Fast is for cold temperatures.
medium is for room temp
slow is for hot temperatures
this is just a generalization though. Look at the tech sheet.
Old Jun 13, 2009 | 01:45 PM
precisionsc54's Avatar
medium
Old Jun 13, 2009 | 02:47 PM
Luke G.'s Avatar
yea i knew them at one point but forgot what the temps where. Thanks for the help.
Old Jun 13, 2009 | 02:56 PM
Luke G.'s Avatar
What type of primer should i get? It is urethane paint.
Old Jun 13, 2009 | 09:25 PM
vsmhatched's Avatar
you should be alright with most any 2k primer. PPG, dupont, spies heckor, sikkens
Old Jun 14, 2009 | 04:26 AM
Luke G.'s Avatar
alright thanks!
Old Jun 16, 2009 | 05:42 PM
jhammond_82's Avatar
Reject Papi
i'd say medium would work best. if you are working in a temp controlled facility, you can use the fast. i used the fast hardner, and it was in the middle of feb/march when i painted mine. i wouldn't do that again, unless it was temp controlled at least.
Old Jun 18, 2009 | 05:57 PM
gsreg94's Avatar
everyone has there own style . i am a painter in the west chester area unless its like 90 out side i would stick with the fast and a splash of accelerator. it'll prevent runs or sags in the clear
1999hondaex
Paint and Body
Oct 12, 2009 01:27 AM
Dsnyneer
Mar 15, 2008 07:39 AM
JCracer723
Welding / Fabrication
Dec 15, 2005 04:47 PM
Jaysun
16
Mar 6, 2005 09:18 PM
GregblkEx04
Oct 1, 2003 06:47 PM
