replacing 1/4 panel and door
Old Jun 21, 2009 | 08:56 AM
icucnme's Avatar
Default replacing 1/4 panel and door
Well I bought a wrecked teg for a project and thought I'd show you guys what I've been fixing. It's not that hard if you have the right tools,knowledge and a lot of time/patience. Just make sure your not getting into something you can't finish. I've been working on this about 3 days a week for a few hours after work. They will be painted black just real quick after I'm done. Cars getting a color change in about 3 months so I'm not gonna make it perfect. Just a quick spray to protect it from the weather.
The worst part is drilling out all the spot welds off both 1/4's. After that it's just all basic body work stuff. I'll post more pics later these are just a few I already have. I had to buy a few things before I could get started on this project.
1. spot weld cutter
2.panel adhesive
3.seam sealer
4.chassis saver
5. special gun for the adhesive/sealer
6. bondo
7. spot glaze icing
8. tube of window weld
9.sandpaper 180-320 grit and some 600
You can see all the holes from the spot welds. There are about 1" apart the entire way around the 1/4 panel. I'd say around 200 of them and x that buy 2 because you have to take the junk 1/4 off and also the one your going to put back on. Also a bunch are hidden behind seam sealer/window/tail light,ect. We cut the 1/4 in 3 different spots...inside the door on the rocker panel"gets covered by the plastic piece"....right were the side window is "gets covered by the window"...right were the hatch line is"only spot you have to make perfect b/c it's the only one you can see"
Old Jun 21, 2009 | 04:15 PM
icucnme's Avatar
Default Re: replacing 1/4 panel and door
Got some more done on it today. Door is prepped and it all should be under primer the next time I go up to work on it. Here are some more pics of what I already had finished. All of the 200 hundred holes from the spot welds are all gone. Iced over and finished sanding them down. The quarter is on the car seamless now. Can't even tell where it was cut.
Old Jun 23, 2009 | 08:24 AM
redsolturbo's Avatar
you did weld the panel/spots on and not glue the entire panel on right?
Old Jun 23, 2009 | 11:07 AM
hotrodshortbus's Avatar
New User
i'd say he did judging by the picture of him welding...
looks good so far though, keep coming with the pics
Old Jun 23, 2009 | 12:23 PM
icucnme's Avatar
Yeah I tacked the panel in a few spots along with using panel adhesive. Most places just use panel glue anymore but I wanted it to be extra strong. The entire car will fall apart before the 1/4 does.
Yeah man thanks for the compliments.
Old Jun 28, 2009 | 03:39 PM
icucnme's Avatar
Ok well I got to finally finish my prep work and tape off the car. Yesterday night I laid down my omni epoxy primer and today I went up and put down the omni 2k over that. Going to let it sit and on Tuesday will go back up and lay down the base and clear on it.
Here are some more pics of my progress so far.
Old Jun 28, 2009 | 07:46 PM
sleepinonacreeper's Avatar
you made a build thread already? i'm wearing the same shirt in both pics.
Old Jun 28, 2009 | 08:03 PM
icucnme's Avatar
Haha change your shirt hobo. Yeah I made it about a week ago I guess. Let's get this POS painted and re-assembled so I can drive it.
Old Jun 28, 2009 | 08:47 PM
Eyger's Avatar
looks good so far. keep going!
Old Jun 29, 2009 | 07:08 AM
icucnme's Avatar
Thanks man. I'll be laying down the base/clear tomorrow evening.
Old Jun 29, 2009 | 10:27 AM
shocker911's Avatar
looks really good man...props to doing your own work
Old Jul 1, 2009 | 08:57 PM
icucnme's Avatar
Well it's finally painted. Gonna let it sit till Sunday then wet sand and buff it. Sorry about the crappy pics but there was still some clear in the air.
Old Jul 12, 2009 | 11:54 AM
egvtec's Avatar
Wheres the update man? I buffed the parts a week ago
Old Jul 12, 2009 | 01:51 PM
prelude1897's Avatar
Good stuff....
Old Jul 14, 2009 | 08:22 PM
91lsteg's Avatar
looks good boob
Old Jul 20, 2009 | 04:48 PM
precisionsc54's Avatar
looking good bro. Check out my build thread. Doing the same thing with the Qp's
ludesrv
Mar 2, 2007 09:59 AM
BigChris
Sep 22, 2003 09:29 PM
DeDonDeRosa
Jun 6, 2003 08:00 AM
Ronin Integra8
Dec 2, 2002 06:16 PM
96Geeser
Oct 20, 2002 06:44 PM
