Fuel pump prime
Old Sep 16, 2006 | 01:47 AM
garyc17's Avatar
Default Fuel pump prime
Hi everyone. I have a swapped out stock pump for a EVO pump. Lately I have been experiencing a problem with my fuel pump priming. It used to prime really loud just before I crank the car. Now I can hardly even hear it priming but the car does crank over. Occasionally on the 2nd crank. Is there a problem with my pump? Will a dirty fuel filter cause this? What about poor grounding connections relating to the pump? Will an old battery cause this? My battery is about 2.5 years old.
Old Sep 16, 2006 | 03:26 AM
RTW DC2R's Avatar
Default Re: Fuel pump prime (garyc17)
whats wrong with the stock pump?
check the things you mentioned. the voltage of the battery, alternator, pump, new fuel filter and see what you get
Old Sep 16, 2006 | 06:51 AM
Tsukuba 699's Avatar
I doubt the Fuel Pump is Bad... it is most likely something with your battery or Ground...
Old Sep 16, 2006 | 10:24 AM
garyc17's Avatar
Which are the critical grounding points relating to the pump?
LS AzZkIkr
Feb 23, 2008 02:06 PM
Cee_mon
13
Apr 27, 2005 12:08 PM
Gman8941
Jul 18, 2004 07:37 PM
_Endless_
Dec 15, 2002 11:29 PM
