Spun bearing - how much to repair?
Spun bearing, how much?
ok so it seems that i have spun a bearing in my motor a little while ago, iv been getting some cash together and was gonna do it my self, but its hard to find a place to do it and time to do it
so my question is how do you guys think it whould cost at a shop, to drop it off, have them dissasemble, replace, bearings, check crank make sure its ok, things like that
like what whould you expect the labor to be on a job like this
Im assuming you are going to just drop off the block and not the entire car(save a ton in labor just by doing that). definitely dont skimp on something like this. no shady little shops on the corner. prices will probably vary greatly depending exactly what you need/want done and where you go.
Re: Spun bearing, how much? (01-0720)
I was quoted $3000 for replacing pistion rings/bearings by a variety of shops. You should probably expect the same.
If its just the block, $1500 or so.
Re: Spun bearing, how much? (Ed 341)
i was quoted by a reputable shop in atl about $2000 for a boost ready fully built block. Which was an outstanding price. It really varies alot from shop to shop and also exactly what you want done also determines how much it will be.
Re: Spun bearing, how much? (mr_gs-r)
good info guys
thanks
yeah i was gonna pull the motor, and drop the block off at the shop, get the rings replaced, have the bearings replaced, and have the crank checked out and make sure its still good, and a new headgasket
do you guys think that whould be around 1500 total?parts and labor
thanks
1500 is probably a good round number. why not throw in a set of CTR pistons while your in there? Get a nice hone, .025 oversized CTRs, new rings, thin head gasket, and while the head is off, get a fresh valve job and valves/seals if needed. youll have awesome compression and the car will feel a lot different hopefully your crank is ok
Re: Spun bearing, how much? (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 »</TD></TR><TR><TD CLASS="quote">how did you do it? over revving? </TD></TR></TABLE>
i was low on oil, and was flying around and on ramp and when i got on the highway i got on it and it didnt go anywhere so i put it fifth and it started making and knocking noise so i shut it off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 »</TD></TR><TR><TD CLASS="quote">I was quoted $3000 for replacing pistion rings/bearings by a variety of shops. You should probably expect the same.
If its just the block, $1500 or so.</TD></TR></TABLE>
your post makes no sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">ok so it seems that i have spun a bearing in my motor a little while ago, iv been getting some cash together and was gonna do it my self, but its hard to find a place to do it and time to do it
like what whould you expect the labor to be on a job like this</TD></TR></TABLE>
sounds about right, but expect it to grow depending on the extent of the damage done to the motor. whil you have everythign apart though i would replace the pistons for some ctr's.
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_gs-r »</TD></TR><TR><TD CLASS="quote">i was quoted by a reputable shop in atl about $2000 for a boost ready fully built block. Which was an outstanding price. It really varies alot from shop to shop and also exactly what you want done also determines how much it will be.
HAHAHAHAHAH JUST FOR PARTS MAYBE>....and that is using off the shelf junk!!!
sleeving 1100
rods 300
pistons 450
oil pump 125
bearings 225
that right there is over 2000 without labor....
sleeving 1100
rods 300
pistons 450
oil pump 125
bearings 225
Re: Spun bearing, how much? (chad)
I think we are talking about just how much the labor is dude, how much is CTR pistons? and what else has to be change to use them.
Re: Spun bearing, how much? (Nataku)
im not looking to upgrade anything
iv decided to repair my motor back to stock, and sell the complete swap
and go with a k20a, the car will be paid off in a few payments, so im gonna go all out with the R and get a new car for a daily driver, my buddy just picked up a impreza 2.5, and i like it alot, iv been thinking about picking one up for a daily driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">i was low on oil, and was flying around and on ramp and when i got on the highway i got on it and it didnt go anywhere so i put it fifth and it started making and knocking noise so i shut it off</TD></TR></TABLE>
same exact situation, i just bought a swap and did it myself it was much cheaper
Re: Spun bearing, how much? (mtber)
new block is the way to go. I think last time I priced one it was about $2200 or so. You can sell the old block and maybe make up the cost to pay someone to swap it.
1 Post
I paid 600 cdn labour for my block to be cleaned up, crank machined, bearings done, ect.. 1000 remove/install labour, and 500 in parts..If you need parts I have brand new pistons and bearings for cheap..I work at honda and bought them for cost and never needed them..
Re: Spun bearing, how much? (410REPN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 410REPN »</TD></TR><TR><TD CLASS="quote">
Actually it does and it answers his question.
$3000 to drop the car off and have the engine rebuilt.
$1500 to drop off the engine and have it rebuilt.
Modified by Ed 341 at 9:26 AM 9/5/2006
Paragraph Alert
You can get a brand new OEM shortblock, complete down to the oil pan, for less than $2,000 shipped to your door. Just throwing that out there.
Re: (CRXnorway)
dude, it's not that bad of a job to do yourself on the floor. just finished rod bearings on a b16 with just jackstands, no lift and it was fine. Your gonna spend less then $100 bucks doing it yourself, and that includes a oil pan gasket. no special tools required, just a little knowledge on how to size bearings which is very easy once you know what your looking for. I much rather save the extra 1500 bucks and make time to do it. don't be scared, it's just nuts and bolts.
Main bearing or rod bearing? You can't just replace those and let it go. Get a short block then when you sell it someone won't be after you for selling them junk.
Re: Spun bearing, how much? (ActiveAero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero »</TD></TR><TR><TD CLASS="quote">You can get a brand new OEM shortblock, complete down to the oil pan, for less than $2,000 shipped to your door. Just throwing that out there.</TD></TR></TABLE>
short block=what? like is that the head and the block or is it just the block no head?
Paragraph Alert
short block=what? like is that the head and the block or is it just the block no head?</TD></TR></TABLE>
Shortblock means a complete bottom end with crank, pistons, rods, etc but with no head.
I got my brand new OEM block shipped to my door for approximately $1900 and sold my old block for around $700.
I'd talk to Len. I'm sure he can give you the best deal available.
