Check engine light Fuel trim malfunction HELP
Old Sep 11, 2006 | 12:40 AM
weirdone86's Avatar
Default Check engine light Fuel trim malfunction HELP
ok i had a fucked up head and drove it for a few weeks and so it was misfiring and running too rich for a while and just shitty in general, but now its all put back together and its throwing a code p0171 (system too lean) and p0170 (Fuel Trim Malfunction). Does anyone know, or have a book to look up what this code means, Like what i could do to fix this problem?? Please help. its stock except IHE
Old Sep 11, 2006 | 03:38 AM
typer_696's Avatar
Default Re: Check engine light Fuel trim malfunction HELP (weirdone86)
You have to hook to a honda scanner and look at the fuel trim parameters.
Old Sep 11, 2006 | 05:08 PM
96BlackHB's Avatar
What's your fuel pressure? When was the last time you changed the fuel filter?
Things to do:
Check fuel pressure
Check fuel pressure regulator
Check fuel lines
Use some injector/fuel system cleaner
Change fuel filter if it has been a while
Check for vacuum leaks
Spark plugs gapped correctly
If none of that works, see if you can swap in a known good primary oxygen
sensor. Yours could be malfunctioning. Good Luck
Old Sep 13, 2006 | 12:40 PM
sp00nek9's Avatar
Default Re: Check engine light Fuel trim malfunction HELP (96BlackHB)
i have the same problem
Old Sep 14, 2006 | 07:35 AM
ITRacer121's Avatar
I would also try and change the MAP sensor. If you have a buddy just barrow his and see what happens.
My R has done the same thing and it was just the MAP being retarded.
OH and what was wrong with your head?
ahtublao
29
Feb 23, 2010 08:21 PM
twiztid_989
Jun 12, 2009 02:34 PM
nv707
Oct 7, 2007 06:11 PM
IwanAturBo
Mar 16, 2003 06:53 PM
