Do ITR calipers come with the 25t or the 23t brackets?
I just ordered a set of calipers from checkers and the caliper itself is correct but what bothers me is the 25t bracket they came with. I thought ITR's came with 23t's?
Re: Do ITR calipers come with the 25t or the 23t brackets? (slofu)
dang...i specifically ordered 97 itr semi-loaded calipers. the caliper is correct though. I'm wondering if all the itr calipers that beck arnley reman come with 25t brackets?
Re: Do ITR calipers come with the 25t or the 23t brackets? (batboyvaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote"> ordered a set of calipers from checkers</TD></TR></TABLE>
that was your first mistake. checkers, partsusa, kragen. the company cant even decide on one name for their stores.
not that you would do this but if somebody else needed just the brackets a company called Dorman makes them and the part number for the front 23t bracket is 619-306
Re: Do ITR calipers come with the 25t or the 23t brackets? (cxSHOE)
maybe return them and order the legend gs dual piston calipers w/28t brackets, mill a few mm from the backs of them (brackets), and get some 28mm rotors drilled with your lug pattern from Brain Hasty @ FastBrakes. it's a heavier setup than the others, but it fits under many 15" wheels and affords superior heat handling.
1 Post
My USDM 98+ ITR front knucle/hub/rotor/caliper assembly came with 25T. It was all assembled like that. It was pulled from a 5-lug ITR at an auto recycler.
Hope that answers your question. I found some other honda-tech articles confirming this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">not that you would do this but if somebody else needed just the brackets a company called Dorman makes them and the part number for the front 23t bracket is 619-306 </TD></TR></TABLE>
Awesome info
Any idea if they make brackets for the rear calipers? I want some pizza pans on the back of my EG as well
Awesome info
Re: Do ITR calipers come with the 25t or the 23t brackets? (Rob_O)
anyone know of anyplace selling rear ITR caliper brackets, i nneed of some badly including rear ITR spindles and the bolts.
jfoster
Suspension & Brakes
03-29-2009 07:58 PM
sumyungguy
33
03-30-2006 06:59 PM
SilverDc2
06-04-2003 07:46 AM
