Circuit Diagram - Fog Lights * Need help*
Hi,
My fog lights stopped working so I check the manual shop of the Circuit Diagram. The problem is that I do not understand where the FOG LIGHT RELAY is on the vehicle because I think the relay is broken. Can someone show me...
Thank you
Frank
Thank you
Frank
Re: Circuit Diagram - Fog Lights * Need help*
the foglight relay is underneath your lower dash, right above your knee bolster. The harness starts out with 2 wires going into the fuse box and goes to the relay and then finally to a 2-pin plug. Dunno if you understand me haha.
Get a flashlight and take that black peice off under your dash. Lay on your back and look up it has its own spot in the middle or the the right of the middle while laying down.
Can someone take a picture of what you're taking about because I don't understand where you mean it is..
It will be very appreciated!
Thanks,
How I did is upload the picture in Photobucket and take the link of the picture with IMG and copy past in the reply and your good to go :D
Alright thanks bro,
I looked over my relay and I think it's not the same as yours. Can you confirm it.. and can you tell me what's the difference between our 2 relay. And can you tell me why I have a white wire not plug in..
Thanks
Pictures to help out!
Thanks
im guessing that's an aftermarket fog light harness? When I did my install I plugged in the white/red and blue wires into the big white block connector that goes in the fuse box.
Its not suppose to be a aftermarket for lights harness but need folks to confirm it to me so I can spot the problem why my fog doesn't work anymore...
Edit: By looking at the pictures you have a 06 si and i have a 07 which is different so that DIY should be money.
BTW how did your foglights work before if that wire wasnt pluged in? Also after you plug everything in if they still dont work,replace the relay, check the fuse in the #6 spot 20amp, double check your grounds, and connections. Turn your wheel all the way to the left and pull back your left fender well lineing(standing in front of your car the left side) and double check that connection, make sure its all the way in because in 3 years its got alot of road grime in it, its hard to get a good connection.
I looked over my connection on the front fender and everything is fine.
The amp 20A was not there before my fog lights stopped working. I don't know if its one of the cause but I notice it. Its weird that my harness not OEM but I think the relay is broken. I will check this out tomorrow and let you know.
Thanks!
Thanks!
Hi,
I'm looking to get the wiring harness for the fog lights. I already have the fog lights, I just need the wiring harness since my harness are aftermarket and something is wrong with it, I want the OEM one. I looked over many website and auto parts but still find nothing. If someone can help me, I will be very appreciated.
Thanks
Thanks
It was my White/red wire. It was unplug and it suppose to be plug in the fuse box. You can see the wire on one of my pictures I posted!
mike11
18
07-21-2011 07:22 PM
EK_kidd
24
10-13-2008 01:24 PM
