View Full Version : Acura TSX
Pages :
2]
11
- please wheres the foglight reply
- Tires???????????????
- Help fix pregnant wife's car - P2647 VSA CEL Rough Startup/Idle
- Does anyone here have Accord V6-6MT wheels on their TSX?
- TSX transmission LSD?
- 2004-08 tsx have same headlights?
- i wanna see what a 1.5-2" drop looks like on a tsx
- fog lights not working?
- TSX Fuel Problem?
- wheel fitment ?
- Will the Quarter panel glass fit - Acura TSX to JDM Accord
- ksport reviews-likes/dislikes
- will a jdm k24a2 fit in 08 tsx
- TSX Build
- 2006 TSX power seat wiring pinout?
- Possible Check Engine Light VSA (!) new solution Please Help
- Need help in identifying a part/cable
- Need some help with what I believe is the charging system...
- power steering squeal in reverse
- 04 with intermittent power steering
- 2G suspension suggestions...
- CMC - clutch master cylinder - DIY
- 2012 tsx oil filter
- '04 TSX Navigation not working, need some opinions!
- 04 tsx transmission question
- 16inch \ TPMS
- 04 tsx p0977 code... help!!
- TSX hesitation
- Anyone own a Hondata flash on a stock auto tsx?
- TSX Picture thread
- 2010 TSX axle
- "check emission system" light/scanner location?
- Navi code. Same as radio code?
- 2012 Forged Silver TSX SE
- 06 dash and airbag fit 05
- dna motoring exhaust
- axle question
- tapping for turbo lines
- A/c compressor
- The road to 225whp in my 04 TSX
- need help acura rsx throttle body
- 2015 ?
- 2006 CL9 | 6M | PWP | Ebony
- EDM headlights & grill
- new 2013 TSX SE
- Aftermarket parts?
- need help with my 2011 tsx
- Question about Ambient Sensor TSX
- Picked up a 2008 TSX. Let me know what you think.
- Anyone got JDM fogs for a 2009 TSX?
- Mugen and 2G TSX
- Will the 06-08 cluster fit and work in a 04-05?
- No power to AC compressor 2004 TSX need help
- 2G TSX CAI suggestions?
- problem starting the car now no more start
- 0 pedal pressure after 1 attempt oin bleeding clutch
- help on conversion
- New TSX Driver....
- New TSX Owner Checking in!!!
- 2G TSX exhaust system suggestions...
- h22a2 with a h22a7 head
- Are the 06'-08's worth it over the 04'-05' years?
- mudflaps for a 2013 special edition tsx?
- will a mugen first gen spoiler fit on a second gen?
- THE FIRST CU2 TSX TO BE TURBO CHARGED
- Is this repairable?
- flashpro base maps
- Ksport Coilovers
- Possibly buying a salvaged tsx
- New Member...
- Rear Driver Side Door Wont unlock/lock
- Work Wheel Fitment Question
- Honda Accord/Acura TSX
- TSX auto trans on Accord K24a8?
- Custom bracket to mount 4-piston RL calipers on a TSX
- 2005 TSX Timing Chain
- tsx fuel,spark problem
- Question About Primary O2 Heater Circuit
- floor mats
- Electrical problem - right hand indicator/flasher
- Stock Mufflers Cut off your TSX?
- In the market for a TSX, what to look out for?
- so i just bought an accord euro luxury ... (cams, vtc, audm, etc)
- Acura TSX not going into gear??
- HELP! Emissions and VSA light issue
- Where are the girls with the 5 or 6 smt???
- New member
- Nice day, why not!
- I NEED A 07-08 TSX stick ECU
- Euro Accord CL9 Dyno Runs/Tune with Flash-Pro
- New to H-T
- New to the game
- TSX + EP3R wheels?
- flooded engine on 05 tsx mt
- 2013 TSX or 2013 Accord Sport Sedan
- '08 TSX - Anything to look for?
- trying to get in the TSX game
- '04-Mystery Oil Leak-NOT Rear Main Seal
- The wife totalled her TSX
- Wheels
- Tsx 6 speed or cl 6 speed
- 04 TSX Stereo Aux port ?
- New to TSX and Honda-Tech
- any1 do the bixenon conversion? cu2
- 2005 TSX
- Throttle issues
- Color code help please...
- Acura TSX timing chain tensioner issue
- Wheel size / offset question
- The most comfortable coil over setup is?
- New TSX owner
- 6 Speed Fly by wire
- 04 TSX , p0705 transmission range sensor?
- Should I get a 04+ TSX or TL
- o2 Sensor Readings and CEL , someone translate!
- How much should I ask for my wheels?
- A/C Problem...Unique?
- Radio Code
- A/C randomly blows hot when its set to cold**Chime In...
- Coilovers ... 09 Si / TSX
- p0443 trouble shooting HELP!
- 2012 TSX Wagon......the Graphite Ghost
- Free Oil Rebate on SlickDeals!
- To stagger or not to stagger ...
- thinking of buying a tsx little help
- Does TSX have transmission problems like Accord and TL?
- Be Honest - do you LOVE your TSX? :)
- 2009 vs 2011 Body differences..?
- interior lights fuse keeps blowing
- A little help ppl Anyone ever heard of Risky coil overs?
- fitment questions...
- 04-05 polished wheels??
- 04 tsx lip questions
- 04-08 Mugen Replica Window Visors
- Spoon-built TSX for sale on eBay
- Some Recent Realtime Pictures
- Any ILX Yet ?
- 2004 TSX non-Navi Radio Question
- putting rsx type s gears into tsx. both 6speed.
- 07 tsx bumper
- New guy working on getting a TSX! couple questions about wheel fitment?
- Electrical issue?
- v6 into 04 tsx, can it be done?
- 06 tsx not starting
- Oil pump timing procedure???
- Looking to buy a used TSX...
- Hello from Seattle!!!
- Anyone have a picture of their 06-08 OPDS unit?
- my gps is not working
- Accord 5 speed swap
- tsx dash lights blinking with keys not in ignition
- Any members KNOWLEDGEABLE abt 1G TSXs in Westchester, NY area?
- Fitment
- Locking doors rolls my windows down.
- 18x9.5 ET30 w/ 235/40/18 - Will they fit? (pics inside)
- 2005 acura tsx convert to 06-07 euro r accord conversion
- Battery terminal corrosion HELP
- Picture request Lowering Springs
- Any aftermarket cat-back exhausts for the 2G TSX??
- speaker dont work. help pls
- tsx gurus needed - ecu issues
- Front End Clunk + Increased Idle Cabin Vibration
- bluetooth problem- iphone 4
- "Driver not recongized"
- What oil are you guys using to lower consumption?
- spc rear camber kit
- altenator 06 tsx
- Does this look Legit?
- 05 TSX Aspec Lip!
- sub in 09 tsx??
- High Gloss Piano Black Door Pillars by CarbonCovers REVIEW
- what kind of paint
- SPrings or Coilovers?
- tsx coilovers
- New to HT but to Honda/Acura
- Something stuck in blower motor fan.
- help. 04 tsx motor blew can i use k24a4?
- Battery question, help please!
- 2004 Acura TSX (Pearlwhite/6speed)
- gas mileage questions
- 1st pic on the forum
- tsx nav dvd
- 2011 tsx What parts are Leather?
- My CL7R with WTCC Body - Video
- BBS LM 18x9 all way round?
- 3 TSX's in one night! dj murdok photos
- 2006 Accord Euro (TSX) - dash/radio switch off and then back on when off accelerator
- iPod Hookup - GROM
- radio code
- my tsx turbo project
- 2004-2005 TSX OEM FOG light DIY Installation
- 6speed swap.... What transmission options?
- Vibration even after changing pads and disks..
- My WTCC CAR is Ready!!!!
- in need of this part ! please and thank you
- thinking of rear deck 6x9 speaker upgrade? [LOOK HERE]
- MDX grill on my 11' TSX
- Keys stolen...What to do now
- 03? tsx motor not running well after 2 years of sitting
- Jan - Feb 2012 TSX: FS/WTB/WTT
- 2012 Tsx tech model.
- looking at getting a TSX, have questions
- Pics of my 2012 TSX SE - Bellanova White Pearl :)
- Tsx parts
- My WTCC EURO R ROAD CAR
- Pro and con tsx
- tsx starting problem
- Video: Slammed 2004 TSX
- Car shaking after coilover install.
- supercharged tsx
- 2004 tsx driver side heater blows out cold air
- 08 TLS Calipers
- Red Acura Emblems
- no vtec help
- Wheel and suspension help
- Rear window vizor/wing pic and review question
- Engine Temp Gauge Fluctuating??
- Hondata to release FlashPRO for 04-08 TSX
- 2011 tsx wouldnt start?
- Tech pkg audio detail 2
- Tech pkg audio detail 1
- TSX vs CSX
- Wheel question, still a n00b with the TSX...
- Mileage changes in ECU or Cluster?
- Nov - Dec 2011 TSX: FS/WTB/WTT
- TSX
- WTB- 04 TSX EURO R Grille
- 2009 tsx compared to 2011
- Somewhat complex electrical issue
- 2004-2008 ROOF RACK??
- Clicking noise when accelerating?!
- 05 TSX - Intake, Header, Reflash?
- 04-05 Auto TSX ECU
- Too much Grease...
- 08 accord k24???
- ur tsx how it looks right now
- need help tsx clearing check engine light
- help!!! will accord k24 fit 09 tsx
- I need assistance with 2004 TSX Homelink wiring
- Question about an '11 TSX with the technology package.
- Euro R with Honda Fit RS
- GREAT DEAL ON DAY RUNNING LIGHTS (UNIVERSIAL)
- wtb 07 tsx grill oem or aftermarket asap.
- Sept - Oct 2011 TSX: FS/WTB/WTT
- loud thump sound whlie turning
- 2009 Acura Tsx just purchased
- A/c Filter
- So, need input.
- faded malono Red Tsx
