Accord 5 speed swap
Accord 5 speed swap
Don't post if you have nothing to add or want to say it's a waste of time.
Finding a 6 speed TSX MT is like finding a needle in a haystack and very cost prohibitive.
Can anyone tell me what it will take to put an Accord 5 speed manual into a TSX?
Want it strictly for fuel economy as there are techniques I can use in a MT car that won't work in an auto.
I know Accord guys swap the TSX trans into their cars so it must be backwards compatible to a certain extent in a 1G tsx.
Anybody have anything helpful to add? Any tips or knowledge they can share?
I don't mind doing some mount fabrication. That's easy.
Specifically looking for info regarding ECU/speedometer/VSS/axles/shifter box.
Re: Accord 5 speed swap
the accord and tsx share the same chassis i believe so the transmission should bolt up with no problem. the tsx parts are interchangeable with the accord just like the eg and dc chassis . and if you can't find all the parts needed to do this u can just buy my tsx
I have no need for 2 TSX's. (LOL).
I know the transmission will physically bolt to the engine considering both engines are K engines. I do believe the mounts are different, but mount fabrication is the least of my concerns. Easy stuff there. This here is the least of my concern.
What axles would I use?
I'm more concerned with the electrical portion of the swap (VSS, Computer, harness etc).
And also the MT pedal/hydraulics/shifter assembly.
Can these be sourced from an 03-07 USDM Accord or do they need to come from a TSX/Euro Accord specifically?
I was hoping someone could shed some light on these aspects. There's not much info out there.
