CMC - clutch master cylinder - DIY
did install Sat morning and pulled the old one out Fri night... woof.
items needed:
10mm wrench for hard lines
12mm wrench for cmc rod adjustment
12mm socket for cmc bolts and booster bolts
10mm socket for cmc reservoir bracket
8mm short wrench for slave cylinder bleeder
swivel for left cmc bolt
needle nose for cmc pin and hard line clasps
unbolt cmc and disconnect pedal. loosen booster bolts as much as possible
unbolt cmc reservoir
disconnect hardline along frame rail
wiggle booster while pulling out hardline
wiggle out cmc and hard line all in one including reservoir... under brake reservoir
swap over needed parts from old cmc to new
reinstall
bleed via slave cylinder
Per ACT, they have come to the conclusion the feedback plate (triangular object at end of CMC) is to blame for failure
Service Bulletin: Hydraulic Clutch Master Cylinder / ACT News // Advanced Clutch Technology
old on left, em2 on right... straight bolt up
items needed:
reinstall
Nickhead
05-20-2011 03:20 PM
Murdah
09-02-2003 07:02 AM
